Bought my current Sony Tv 3 yrs ago.Still workg fine.Wonder in 3 yrs time will X9000F still be in stock?(moving to new flat).
Currently own a Sony 40inch TV which is used for abt 7 years. Jn went gain City to view 55inch sony 4k tvs. Got 2 version, smart and android. Smart is $1999 and android is $1979, so price is abt same. Didn't take not of the model numbers but both got sticker say is 2018 versions. Which version shld i get? Android or smart?
Sent from Samsung SM-G955F using GAGT
Or should I top up abit and get the 55X9000F? About $2699 but maybe can squeeze more discountYou should get android but the price they gave you is too expensive.
My usage is more of watching Netflix and Movies from my PC.
The difference in the OS performance between the A9F and older Sony Android TVs is extremely extremely huge.
Harvey Norman Suntec has a 65A9F placed right beside a 75Z9D. The same Sony remote can be used to control both. So you can easily verify their UI performance differences.
IMHO, unless you are going to use many of smart features on the TV, there is little reason to favour the newer model based on the better/faster navigation.
On the other hand, the demo clips on both TVs are quite similar so can easily compare their PQ. I find the Z9D vastly inferior.. especially in the area of contrast, color and image depth. The newer Sony is supposed to be better in fast motion scenes as well, but can't adjudge no thanks to the clips used.
By the way, I own the A9F and I also own another Sony TV with the older chipset.
Point noted. Thanks.
Can you share your experience with the 65A9F?
Good deal not ?![]()
