Sound Cards
Skallzz
I am looking for a sound card with a Line In: 2 x RCA (L / R).
Any recommendations?
The audio card will be connected to a home theater system
Skallzz
sound blaster ZXR has that but it is too expensive.. any other card with something like that?
Skallzz
Xonar U7. USB though. I'm using one.
is this an external sound card or how does it work or?
can get more details please cause it could be what I am looking for
In my box currently is a creative pci sound card.. its the blue recon 3d lol
harharhar
You can say it's an external sound card. Plug to your USB, install drivers, good to go. Up to 7.1 surround.
It has separate amp for speakers (rear) and headphones (front). Amps not changable, for that you might have to look at higher end stuff like creative soundblaster X7.
Skallzz
Bump Bump
So i went and got the Xonar U7.. however its only 2 ch.. any other niffty gadgets to make it a 5ch.. note I'm trying to go low costs.. that creative X7 is way to expensive...
enenyi
Bump Bump
Isnt the U7 already 5-channel, with ports for centre/sub, left rear and right rear? Just go to the U7 software and change from stereo to 5.1 will do.
ragnarok95
Senior Moderator
Senior Moderator
Bump Bump
Your U7 support until 7.1.
Skallzz
Sorry to bump twice in a day.. but I managed to switch it 5.1 ..
however I am using RCA to connect from my home theater..
So how does that work eh hehe
Sorry I need alot of help figuring stuff out.
wwenze
Draw a block diagram of your whole system connected
Skallzz
Do not need to lol..
its as a 5.1 home theater system 2 front 2 back 1 center..
connected to the U7 using RCA (Red and white)
switched the system in U7 to 5.1 but its RCA .. so standard 2ch I suppose?
anyways to work around it to make it a whole 5.1 ??
magix
RCA only 2 channel.. think u need to go optical.
Please correct me if i am wrong.
magix
There connect to SPDIF
Clearly stated say support 4.1/5.1/7.1 and etc
There to your AVR
Lastly the setting must be correct to get 5.1
- Video clip and software also must support (correct me if wrong)
- I know the Sound card console must set output to SPDIF and 5.1 setting.
MasK
Yup. Old skool RCA is only for stereo, 2 channels.
U7 does not support optical.
However, it supports coaxial (SPIDIF connector), and provided your HT system accepts this as well.
There are optical-coaxial/vice-versa converter available if you need those.
If your HT does not have any coax/optical at all, the U7 supports analog 5.1 out as well. They're marked centre, side, rear. HT needs to support these too.
Maybe it'll help if you describe you HT system. Is it a standalone amp or those all-in-one HT with speakers and BD player?
If it's an Amp that supports HDMI in, I'd recommend that instead. Audio/Video through one cable. Don't even need the U7 for that.
EDIT: Darn.. magix beat me to it while I was typing.. haha :)
Skallzz
Thanks all for the help..
I guess thats it then .. I have no choice to RCA.
cause my HT's optical port is damaged.. no its not my HT.. it was given to me .. and that time was half gone in terms of the port. and since its a given item.. I have checked and its already out of warranty
if anyone wants to know the model of the HT is LG: HT762PZ-A2
thanks all for the help
