Sound cards
tsteo77
Does anyone know where in SLS can i get this soundcards, Sound Blaster Z and Sound Blaster Audigy RX ? Thanks .
Rashkae
Oh you mean cards
Most shops have them like Cybermind Fuwell etc. Or order on Lazada or direct from Creative.
Trans-Am
Why not buy at creative online store?
Iirc that time free delivery
Sent from A universe Where pink PWNED everything using GAGT
skrekro
Thanks,
I not able to install on my own.
Why not? It's just a matter of removing side panel, remove one bracket (1 screw), plug in the soundcard there to pci slot and then connect front panel wire to it.
wwenze
I don't see any reason for a sound card for a typical user these days.
Jurchen King
I think the onboard Realtek sound for most motherboards is of acceptable quality for most users, unless you really have high fidelity speakers connected.
tsteo77
Finally i found the souncard at cybermind. I brought a audigy rx sound card for $89 which is $10 cheaper than creative online store.
To me audio is as important as graphics in gaming / music. using sound chip is like using IGPU.
abstrax
I am using Z series too...much clearer than realtek...
skrekro
Should've bought a dedicated amp+dac combo like objective2 if you were really serious about audio
vironix
PRefer external usb dac/amp so no interference
Sent from where? using GAGT
Yongkit
Agreed, perhaps TS have budget in mind for the soundcard, also we are not sure if he is using optical cable for his speakers too.
