Loser
- May 7, 2019
Soundcore has released its next-generation flagship true wireless earbuds... Take a look at Liberty 3 Pro!
Key Features
Color options will include:
Key Features
- Recommended by 20 GRAMMY Winning Producers
- Golden Sound: Astria Coaxial Acoustic Architecture 2.0 is the latest version of our groundbreaking coaxial driver technology. A 10.6mm dynamic driver and a balanced armature driver are aligned on a single axis to deliver pure, detail-rich sound to your ears. With its upgraded structure and materials, pure sound is delivered directly to your ears. Bass is strong, mids are enhanced by 150%, and treble is increased by 460% for an ultra-wide and immersive soundstage.
- Personalized Sound: Each of us hears music in a slightly different way so Soundcore's proprietary HearID technology intelligently tests your hearing and creates a tailor-made sound profile that's unique to your ears.
- Tailored Active Noise Cancelling: Liberty 3 Pro's active noise cancelling automatically adapts to noise levels in your surroundings. It's enhanced by HearID technology, which analyzes in-ear pressure and the way noise moves within your ears to create a personalized noise cancelling profile.
- Multi-Mode Transparency: For total awareness of your surroundings use Fully Transparent, reduce low frequency noise and amplify voices around you with Vocal, or increase the volume of voices further with Enhanced Vocal.
- Hi-Res Listening Experience: Liberty 3 Pro noise cancelling earbuds support LDAC mode, a Bluetooth codec which transfers 3x more data to preserve details and sound quality.
- 3D Surround Sound: The algorithm processes audio in real-time and enlarges the sound field for an instantly immersive listening experience.
- Exceptional Clarity: 6 microphones and an AI-uplink noise reduction algorithm filter out background noises and enhance your voice in real-time so you can be heard clearly.
- Multipoint Connection: Connect Liberty 3 Pro noise cancelling earbuds to 2 devices and switch between them effortlessly.
- Long-Lasting Playtime: Enjoy up to 8 hours of music (at 50% volume in Normal mode) from a single charge of the wireless earbuds and extend the playtime to 32 hours with the charging case. If the case itself needs recharging, simply place it down on a wireless charger or use the included USB-C cable.
- Wearing Detection: Sensors in the earbuds detect when one is removed and pause the music until the earbud is returned to your ear.
- Fusion Comfort Fit: Liberty 3 Pro’s earbuds have a triple-point ergonomic shape and built-in ear pressure relief for all-day comfort. 4 sizes of liquid silicone ear tips and flexible ear wings ensure you get a strong seal and secure grip.
- Easy-to-Use App: Use the Soundcore app to choose from a wide selection of EQ modes, activate 3D Surround Sound for immersive listening, customize the touch controls, and more.
- Dusk Purple
- Fog Gray
- Frost White
- Midnight Black (pictured above)
