Computeron
- Mar 22, 2005
I just tried.. Not bad.. Haven even tune the eq yet
May I know where to collect one?Previous experience is auto applied as platform discount during checkout. But you have to collect those vouchers. The collection is daily started earlier this month.
$180 for export set is even cheaper than launch discount. How they earn?qoo10 cheapest $216 local set.
$180 for export set.
donno. leh... donno want to hoot export anot$180 for export set is even cheaper than launch discount. How they earn?
Mine is not the upgraded 2 pro, so more worth to upgrade. But if you don't want anc, better battery, maybe smaller size, then guess no point going for 3 proThe 2 pro also has ldac.. And dual hybrid drivers... So what's the different with 3?
ANC not better than sony's.Some review compare the anc better then Sony's... I am really tempted... By the hybrid drivers.. Cause I have the soundpeats h1.. I know how powerful the sound can be.... But seriously talk about sound quality ldac + hybrid drivers (know + dynamic drivers) are the best u can get... But in term of connectivity aptx adaptive is still the more stable one...
Ok.. The apps got way to set 990kb? Or is fixed...? The app got setting for priority for quality and connection right? U set connection also got drop? If have I cane tell u same as mine 1000xm4.. Occasionally will have drop if phone in front pocket... Funny is before firmware update no issue leh.ANC not better than sony's.
I can tell you now so don't get it if you want top notch ANC.
And I experienced quite a few drop ours already. But still acceptable.
App can set ldac or aac lor. I use mine in non ldac exclusively because no lossless source also no use.Ok.. The apps got way to set 990kb? Or is fixed...? The app got setting for priority for quality and connection right? U set connection also got drop? If have I cane tell u same as mine 1000xm4.. Occasionally will have drop if phone in front pocket... Funny is before firmware update no issue leh.
ok thanks... i checked if on LDAC + ANC this 2 i use often.. th LP3 only 3 hr play back vs sony 5hrs... think will stick with sony until the LP4 is out with better battery life.App can set ldac or aac lor. I use mine in non ldac exclusively because no lossless source also no use.
