speed up bootup
wtfwfs
Hi all...
My os is installed on ssd...
Just thinking how to make it boot up fast...
And also how to make it load faster....
tweak ram or overclock?
skjh7`
Hi all...
Think on start up you have too many unnecessary programe that is loaded during start up.
wtfwfs
How to also make the browsing speed fast. Like internet fb n all...
ragnarok95
Senior Moderator
Senior Moderator
U surf website want it to load faster got anything to do with ur SSD meh??? SHould be your network right???
jtjt00
Boot: run msconfig to disable most except your security software
Surf: get fastest fibre plan and use LAN connection.
yusoffb01
To bootup faster, install windows under UEFI (GPT), instead of MBR.
For slow internet, change your singnet dialup to fibre
hsComu
tell what is the timing now - might be everything is ok already? (btw both options won't lower boot time)
browsing speed don't depends on hw, consider to check speedtest.net first then go to Networking Clinic :)
killerslayer92
hope ts is not expecting 2s bootup time :s13:
ssd is the fastest way to go alr. more ram wont help.
network speed use wired to improve latency. upgrade plan to increase speed. your router might be the bottle neck tho. note that old router say they support gigabit but not true gigabit bcos the processor and ram of the router not enough
