SRS questions
blasterlord2
Hi, can I check with you guys, I bought some etf with srs account long time ago but never check back on it ever since. How do I check the investment details of my srs and what happened to those dividends over the years? I used phillip securities to purchase, if this info is relevant.
Sorry if these questions have been answered before here.
CarManiac
Login to your agent bank account and check under SRS. For mine, it would shows under SRS Account after login to DBS.
blasterlord2
Thanks for your reply. Then I presume those dividends are deposited into the srs account and not reinvested automatically?
Okenba
I doubt the bank has details of your investment. It will tell you how much you have in SRS, but for investment details, you should probably log into your Philips accounts.
limchooc
Unless the eft you bought offer script dividends, dividends is credited to your SRS account.
yuzu28
if u using ocbc srs, u can download the statements, u can see the detailed transaction there. if u use poems to buy, using the app dun think u can see srs but via PC, u can see the holdings but not detailed transaction. this is my experience, maybe i dunno where to find only.
Kojo0403
For OCBC agent bank, the investment and its present value should be shown on the app under Account. At least that's what showing up for the ETFs i bought.
