St. James Place Wealth Management
Shiny Things
Anyone had any knowledge of this company?
A quick google says that they seem to be a real company, which is a step up from a lot of the rubbish we see on these forums. They’re based in the UK, though; I’m assuming you’re a Singaporean resident, so why would you want a wealth management company that doesn’t know the Singaporean market?
JuniorLion
Thanks ST!
My friend works for the Singapore branch here and approached me to consider the products. Hence, I needed to find out more information..
Tomutomi
This is what i found after searching info on SJP.
andrewhallam.com/2016/03/singapore-expat-should-you-invest-with-st-jamess-place-international
They are charging 2.55% fee, lower than other competitors (e.g. insurance and bank in SG usually charging 3-5%), surrender fee also much lower.
Though you can always buy low-cost ETF directly which accumulate better return over long term.
Look at the comparison of long-term return between ETF against other funds here:
blog.seedly.sg/why-you-should-buy-a-low-cost-etf
Thanks ST!
JuniorLion
Thanks a lot for your search =)
