minamikaze
- Sep 30, 2016
Thank you for your info - it's the 1st time I'm trying out a mesh system. I was intending to put the unit in the DB box.. will need to experiment a bit, maybe put the 2nd unit in my living room.The Nokia will support both Ethernet backhaul and wireless backhaul.
It is a low end dual band AC1200 mesh solution. Performance will not be good with wireless backhaul. And the second node needs to have good connection to the main node. Try to make them have line of sight if possible.
