Starhub Giga
loganrunning
My Mom's Redmi 9T suddenly cannot make / receive any calls at all - no issue with data or data calls..
Tried all troubleshooting (APN swap - restart phone etc etc ) and NONE works - anybody having the same issues?
Very frustrating with their non-existant customer service...
if it still does not work after enabling VoLTE, check that it is on the starhub supported phones list.
uncle_josh
y2k_tay
May I enquire which other telco did the 3x lines port out to?
Am using Huawei P30 Pro and also faced this issue, because giga somehow didn't support it even when it was working previously www.giga.com.sg/FAQs_Details.aspx?QuestionId=4938
I tested ported out 1 line to eight mobile and am looking at other lines in case volte calls aren't supported on my device through eight mobile.
zero.zero1.sg/announcement/4g-5g-mobile-devices-that-supports-volte/ - Support (Last updated 09 Apr 2024)
www.m1.com.sg/support/cessation3g -Unsupported
www.gomo.sg/content/dam/singtel/personal/products-services/mobile/prepaid-plans/Terms%20&%20Conditions/list-of-supported-phones-3gclosure.pdf - Unsupported
Unfortunately not yet, but will be porting out this month cos billing cycle just started. Was considered to port out last month but may not in time for port over to new Telcos cos left few business days.
Had tried on M1 and Circles.life.....no issue and able to support voice call. The signals on their devices shown volte...... So I believe it's giga that cannot support these devices.
If your eight mobile can support voice, I may ask them to consider since the plans are attractive!
StormX
Hi. Anyone working at Tuas? How is Giga network at Tuas? Considering to port over from M1.
loganrunning
Not working at Tuas, but occasionally travel to Benoi sector and tuas extension (biomedical park).
eight is ok for both reception and speed (it's on SH infra, same as Giga, so I assume the performance should be similar).
just my personal experience, YMMV.
Jirachi
Are you currently on 4G M1? If 5G M1, technically it is going to be the same due to Joint Venture.
pepperminttea
Anyone encounter issue of intermittent data connection lost?
I'm on Giga's 4G with Samsung S23 Ultra and throughout the day the 4G icon will disappear and then reappear about 10 seconds later. This started about a few weeks ago I think.
Me too. It could happen anytime anywhere. I could be at home and it's gone suddenly. I could be on the roads and it just drops off. I hate it especially when I'm on android auto using maps. It just disconnects and gone, no GPS -_-
saggice
No issue on my S24U with my freshly ported back Giga 4G today.
Check your Connection settings
Try disabling WiFi calling, toggle your Giga SIM off and back on, and also run update all SIM cards on setting page.
Thanks you! it still cannot and i ordered a new giga sim card just delivered, and still cannot work.
highsulphur
Upgraded to 5g on my oneplus phone even though it was mentioned it wasn't supported by giga
It worked
Insatiable_creat
Was intending to switch to giga 5g from m1, but sian after seeing some here switching to eight.. lol.. maybe I should go for 8 too.. paying $20+ for m1 every month..
loganrunning
currently m1 4G or 5G?
if 4G, eight is 4G but in my experience, a much better deal - YMMV
if 5G, you may find not much difference on giga 5G, and eight's 4G not as fulfilling
since eight is no contract, suggest you get a new line and try it out for a month or two. Especially if this is your primary/sole line
Insatiable_creat
Was on M1 5g, pretty pathetic speed imo compared to my partner's 4g. Lol. So I just downgraded few days ago.
Thanks for the recommendation!
Jirachi
M1 5G and StarHub 5G are practically the same thing because of the JV. Are you sure your experience is bad because so far, including myself, I really like M1 5G. Way way way better than Singtel.
Insatiable_creat
No chance with Singtel yet. Though I will assume they are the best?
M1 not fantastic to me like the usual dead zones along NE line, poor connection occasionally, and no significant speed improvement to me compared to my SO's M1 4G.
Jirachi
Oh that is just for me. Singtel never worked for me well since 2021.
