*UPDATE On Post #6*
**Setting Up Home Automation Using NFC Tags with Home Assistant**
Some may ask why you still need to use NFC tags when you have already set up scheduled or planned home automation using home assistant. Well, sometimes, you might want to set up custom scenes or "call service" (turning on your hi-fi while you are on your bed) in you home assistant to fire only when you made contact your mobile with the NFC tags. You can learn more from the video below, I recommend using cheap sticker-like NFC tags or pebbles if you want to implement NFC tags in your smart home.
**Integrating pfSense firewall with Home Assistant for Remote Monitoring**
Some have asked me what could be a good way to remote monitor (or a quick glance) of their pfsense/opnsense firewall running at home. In fact if you have been using "Home Assistant", you could integrate your firewall appliance with the (opensource) smart home supervisor. Below I will cover the basic step-by-step guide for integrating pfsense with HA.
NOTE: Some pre-condition before you follow this basic set-up. You must have an up and running HA server with HACS (home assistant community stall) installed and properly configured.
I have covered it here on Post #4:
https://forums.hardwarezone.com.sg/...tant-ha-for-new-users.6751695/#post-141707390
*STEP-BY-STEP GUIDE*
Step 1: Click Explore Icon at the bottom from the "HACS" tab. Search for "pfsense integration for HA" and click install integration. After installation, you will need to reboot the HA host under configuration -> add-ons, backup & Sup -> System -> Reboot Host. Ignore the "pfsense gateway monitoring" integration which is no longer supported.
Step 2: After reboot, log back into your HA supervisor. You will be able to find the pfsense integration under the Configuration -> Devices & Services -> click "add integration" tab at the bottom right -> search for pfsense -> key in the settings as shown and click submit. (Note: URL will be your firewall IP address)
Step 3: Add card under the lovelace dashboard and select the monitoring entity under the heading of "pfsense". On the right, you will be able to preview the dashboard card. Feel free to customize your lovelace dashboard to your liking or download custom themes to spice up the outlook.
Step 4: You can create a separate dashboard tab and name it as "pfsense", select vertical stacks and customize the pfsense monitoring entity you want to view at a glance (Eg. services, software upgrade, etc). I also prefer to create a separate tab which is more mobile friendly, where you can easily have a glance of the Gateway status of your pfsense.
Want to learn more on setting up your own opensource firewall appliance, can check out my pfsense thread here:
https://forums.hardwarezone.com.sg/threads/starting-pfsense-for-new-users.6390714/
