@TanKianW following this thread now!
Based on the below quote, i'm most interested in hitting above 1G for combined usage yes! Is Load Balancing possible when both ISP is different speeds? 1gbps + 500mbps?
Also looking at the setup options, wah i quite blur sia... hahahaha. Can anyone recommend? These are what i want:
1) I currently have an i7 Intel NUC, would like at least same/better processing power from these for Emby/Plex server I want to run
2) Enough WAN/LAN throughput to support 1Gbps + 500mbps but also future proofing for 10gbps
3) Processor/RAM enough to support heavy torrenting as I run a seedbox
"Set" at 10k. You no need to hit 10k in order to achieve your max DL speed.
I am not sure with VQ. I managed to get load balancing set up on M1+MR (static IP) and ST+MR (static IP).
You will hit >1G from "running tests/benchmarks". Realistically, you will only hit >1G on combined usage. (Eg. My kids using M1 for netflix streaming, I'm using VQ for DLing). I have never hit >1G (max~850Mbps) on a single P2P box (unless doing 2 different tasks/connections at a single time). But with two P2P devices, I will hit a combined usage of >1G. Take note that your bottleneck will also be at your devices side, if it is only at 1G.
I believe your Cisco router is using 1G for downstream LAN, thus can't go >1G on client (receiving) side.
You can build your own pfSense box (mini pc) OR check out Page 1 of my pfSense thread on the other Options.
