static noise from speakers
StopJoking
hi, recently im having static noise from my speakers/earphone.
Speakers plugged into motherboard and earphone in the front port.
Would getting a sound card solve this problem?
Thanks for any help given
addthewin
i used to have that problem..
asus xonar in particular is good at this area.. because it draw power from floppy connector (which means you need to attached a molex to floppy connector) so the power is directly from PSU and the power is "cleaner".
power from motherboard are generally "noisy"
but spending like $100 for that, is it worth it? personally i have a mid-high end speaker and i enjoy quality sound a lot.. but to general public they may not be amazed be the "incremental" gain in quality.. if your speaker is low-end i suggest you save your money and ignore the static..
StopJoking
im using this speakers currently
Altec Lansing 621 2.1 Speaker System (Page 1/5) :: Articles :: www.hardwarezone.com®
i found asus xonar dg price still not too expensive
Amazon.com: ASUS XONAR DG Headphone Amp & PCI 5.1 Audio Card: Electronics
most likely should be able to solve the static?
addthewin
this is the PCI version.. check if you PC has an PCI slot.. do note that PCI and PCI-E is different. why don't go for the newer version. better support in driver not sure that PCI version has latest driver for win8 for example..
StopJoking
my current motherboard have
1 x PCI-E x16 2.0 Slot (x4)
1 x PCI-E x1 2.0 Slot
2 x PCI Slot
saw many reviews that the front panel amp not working for the DGX(pci-e) version.
any other cards <$50 to recommend?
