Sufficient Power???
gamma15
Hi,
I plan to upgrade my GPU to 7950 with the bundle for game...
but not sure is my PSU sufficient for the upgrade?
Spec as signature --->
Thanks
Maeda_Toshiie
Google turns up a lot of results, Extreme Power Supply Option (Link).
Another options, if you prefer
1. Corsair Learn & Explore
2. Thermaltake, though its the same version of Extereme Power Supply Thermaltake Power Supply Calculator
Not good. Those PSU calculators will badly overestimate PSU requirements.
If you buy this kind of crap:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=204
Then you will need to oversize like what those "calculators" recommend. Otherwise, buy good quality PSUs which end up being more efficient and give you a peace of mind, knowing that they won't easily blow up if not badly abused.
