Suggestion for an overheating issue
zelda3d
Hi,
Any suggestion to improve my current setup?
I currently have 2 140mm front intake fans and one 120mm exhaust fan. I find that if I remove my side panel, the PC won't shutdown under heavy gaming(BF1).
Should I add 2 more exhaust fans to pull out the hot air or add another fan intake on the bottom?
wwenze
There is a broken fan / HSF somewhere that is not the chassis fan. Fix that instead of adding more chassis fan.
zelda3d
what is overheating? the cpu or gpu?
No idea, PC just go boom(turn off). Before it goes boom, my gpu is at 60 degress, cpu also at 60 degress.
Buy some gentle typhoon fans and add into it. Your pc hot air is circulating.
My fronts are 2 pcs of Fractal HP-14, maybe tot of swapping them from a pair of HF-14 and use them for top exhaust
Are gentle typhoons fans better?
Have you tried to change the flow direction of the side exhaust fan so it draws cool air from outside and blow onto the mobo and gpu?
If it doesn't shut down maybe u can consider adding one exhaust fan some where at the back to draw out the hot air.
Sadly, windowed side panel, no holes for a side fan
All are rather new parts except for the ssd and hdd
yusoffb01
install aircn in your room.
if no money leave the sides open
hlots123
shutdown at 60c gpu & cpu...?
can u try turn off fanless mode for psu
and just check if casing & cpu fans are at max speed during gaming...
zelda3d
poooooo
60 degree very unlikely to cause your build to shutdown, might be other issue....
zelda3d
This actually make sense. Could be psu issue also.
At first I tot it was psu, took another psu from my fren and tested, it still turn off by itself during gaming. But with the side panel removed, I can game with no problem.
Note that all test I did, I undervolted the gpu to the lowest values available in the afterburner. I think my chassis traps alot of heat in it...:(
sacredrays
hmm.. your casing can remove the top fan hole cover right? try removing that see see?
btw, how hot your casing gets when you game? maybe your exhaust fan settings should put at higher speed..
archyng
my pc brand new used to restart on its own.
i went back to pcthemes they changed the ram for me.
still had problem.
so i put a certain timing for win10 auto update.
change to another wall powerpoint plugging it directly in.
after which no problem.
might be wall powerpoint or yr multiplug issue.
zelda3d
My top vent opened liao, but no fans and the rear fan is only 3pin, doubt I can tweak its speed
still had problem.
Not using win10 but can try the replacing the multiplug
sacredrays
go bios and check first before doubting... :s22::s22:
edit: hmm.. you using itx mb.. so only got 1 sys fan input on mb. that's why you can't change the fan speed... is there a switch or something your fans are plugged to before connecting to the psu? turn it to high...
llesuoracniatpac
Bro, your gfx card isn't reference right? Then you should really just populate the Nano S with fans all over. Get matching fans as your front intake for top exhaust, then get a stronger fan than your rear exhaust for bottom intake. This way you still get positive pressure. Your AIB cooler card, while better than ref in all other scenarios, is a killer in ITX rigs. Unless your ITX has good airflow, the ref blower style always beats open air. As other bros said, that GPU is dumping heat in your chassis and it is being circulated around. Also, you might want to repaste TIM for both GPU and CPU, but just try the fan config first and report back.
