Suggestions for electric dust blower PC
shengheee
Hi, Could someone recommend me an electric dust blower to clean my PC?
I've been using the dust can a lot and i think it is not wallet friendly.
Vulpix
Moderator
Moderator
Ok! Thanks Mythmaker, let me look around for another alternative, $100 a bit too high for me :/
It may feel expensive but their quality is top notch. Mine is 9 years old, I use it every few months. Still as good as it was the first day.
Mythmaker
Actually even though mine is extremely strong and runs on AC, those dust that are stuck on the pcb still wont come off. If you are looking to get rid of those, you probably either have to wipe it or use the blower every week. I highly doubt those portable handheld blower/vacuum will work since mine didn't.
shengheee
Wa. All the pros recommend to use the METRO datavac. I think I go see see where got kangkao for discount and buy ba. Thanks everyone. :)
Mythmaker
I also use it for... another purpose :o
I used to blow on lizards, then they will stop moving (they wont get blown away, instead their limbs will double down akin to us moving against a typhoon) while I catch them easily and move them out of the house :o
shengheee
LOL. Let me try when i get my hands on the blower. My house knn got a lot of lizard.
