Suggestions/Help for Hot GPU/Case
rainky
Hi Guys,
For starters, I'm using a TT Tsunami Dream for...years.
I have just cleaned out my front filter. Fans are all stock.
Cabling is pretty *decent* although I think it can be better.
My idle GPU temps are at 61 deg, running MSI Twin Forzr ii OC.
on load, while TF2-ing, it goes to maximum 85 deg.
My previous GPU auto shut off my pc becuz it goes to 110deg while TF2.
Any suggestion what kinda aftermarket case fans should I get? I dont wanna get watercooling cuz too troublesome :X
Thanks!
congrade07
Pour water onto the card or place some ice on it~~~ hahaha
Just joking...
If GPU hots and dont wish to go WC, you will need to ensure there is a good airflow provided you have a good airflow casing.
But to really have a low temp gpu, WC is the way to go. Imagine I am running dual 680s at only 40 plus to 50 plus degrees max. Low temps helps to prolong your stuff also
wuweiz
Can try check out Coolermaster fans.
Take note of speed n noise level. I won't take anything less than 1200 rpm for 120mm fans.
But not sure what size or how many u looking at.
