Surface Pro (5)
Fullstop197
Actually I didn't had a good impression of Surface Pro because I was considering a laptop/ tablet hybrid.
So I bought the Surface Pro and then I ordered the brydge keyboard online. It really is magic.
joesph
surface pro doesn't move when tap screen in compare to touchscreen laptop
Sent from Samsung SM-G950F using GAGT
joesph
22-28 February i5 128 with type cover $1488
MSFT online $1338 without type cover
Cashew_Nut
One major benefit that ipad pro has over surface pro is the power cable.
I think I'm right that SP uses a power block like most laptops, but the iPad Pro uses just a USB cable. Is that correct? If so then that's a major advantage that the iPad Pro has over the SP especially as I travel a lot and less is more.
joesph
I saw same brydge keyboard for surface pro 3 to 5. lol by epicenter basement 3 ion S$269
ExArchz
Hey all, what kind of mini display to HDMI adapter are u all using. The original MS adapter $64 a little xiao expensive. Using just for school presentation. Display quality a little cui no issue, can use can le
joesph
daiyo?
joesph
charizard1987
Do anybody face battery drain afte shutdow? :s11: My battery drops 30% when i turn it on the next morning...
