switch between wifi and 4g network
daylight
is there any apps to switch between wifi and 4g network on note 4?
eg. when at home/office i have wifi connection, it will use wifi and disable 4g.
when outside, it will turn on 4g and disable wifi ?
any one using any apps to manage these ??
renfred89
to do this, i think your phone has to be rooted first... not too sure about how it goes, but isn't it easier for you to do it manually than to go through the hassle? :p
ATN888
auto on/off wifi no problem, but mobile data needs root (on lollipop).
still workable if u're not concern it uses 4g when there's no wifi (data always on). Just set "keep wifi on during sleep" and then play with auto wifi on/ off.
Can check out free Llama location profile, its free. For more then maybe 'Tasker'
