System Reboot Instead of Power Down
swathe
6/10 times, especially after long use or when I game. Everytime I shutdown Windows it will become a reboot. I suspect it to be during the shutdown sequence it has an issue then the system auto reboot.
Other symptoms I have encountered is that, if i am playing a mid range game, the PSU suddenly cuts off power and reboot. It feel that it is a power cut off because unlike a usual hang auto reboot, I can hear the entire system power down and power up.
Eg, it feels like the reboot when you upgrade your BIOS, rather than a windows restart.
Is this a PSU issue and need to RMA?
jtjt00
TS, list down all parts of your rig like those on the right -->
ZrE0_Cha0s
what's your system? and is your psu seasonic?
anyway there is some possibility with your mobo as well.
swathe
Seasonic G-550 550W PSU
2x HDD
Palit GTX 950
Intel Northwood CPU i5
ZrE0_Cha0s
have u tested with your mobo gpu and see? see if it power down as well?
swathe
Paiseh, Sandy Bridge i5-2xxx.
I tried changing GPU, also the same problem. Never tried Intel GPU because old setup. Mobo no graphics port, so only use discrete PCI-E Cards.
Never overclock anything, all stock stuff. Highest temp was 60+ degrees only.
Humster
What is the game? Does the game have any recent updates?
swathe
World of Warships at 1080, medium. Not a very high demanding game.
Game is updated at launch. nVidia drivers also the most current.
swathe
Should I just RMA the PSU? Likely not GPU issue because I changed it once.
