system stuck in a on and off loop
ecce13
whenever i try to boot up my system, it will turn on for about two or three seconds, occasionally a little longer before it just shuts off without a warning and then goes into the loop of booting on and off. because of this i haven't even got the chance to install my operating system. is there anyway to solve this without going down to a service center? this is a newly built pc and i have actually asked the place which built my pc, they suggested to remount the ram, i have tried that but it didnt work. i tried starting it up without the ram but the problem persists. i have a feeling it might be the problem of the power supply as everything else lights up and it occasionally gives a bios beep before shutting off when there is enough time. when its shuts off it looks like a power trip kind of thing, it shuts off without a warning. the specs are the ones i currently have in my profile, i hope someone can help me because i really want to use my computer and its new...
jtjt00
Is the rig profile on the right is the desktop having issue?
Are all parts new or some are re-used part?
ecce13
yup the rig profile on the right is the one having issues, and all the components are newly bought and its assembled in the store itself so im not sure...
jtjt00
Try the following:
1. using 1 pc of memory, swap if fail
2. remove GTX960 and use onboard GPU
At the shop, they boot up to show you to BIOS screen?
ecce13
yup they showed me the bios screen in the shop, i tried testing the ram one by one but it didnt work either, i'll try testing out the onboard gpu and see if it works
ecce13
i tried powering it up with the onboard gpu, the booting slows down but its still goes into a on and off loop, just that its a longer process, furthermore the bios screen doesnt show when i swap to the onboard gpu, my monitor will have no signal
ericccc
same with mine last time, my one is the motherboard spoilt. the psu and memory works good on new rig.
Exaita
High chance motherboard spoil... you got any other hdd to test?
SexMuffin
I have the EXACT same problem. Except for mine, my rig was working good for a 1 year +++. Now im unsure if i should buy a new mobo or psu...
