Go tag replace lo
If u wan also go to reputable ones like hour glass etc but ask if they can do in the spot in front of u
if you are not going into water with it, simply unscrew the back and replace yourself = $2
$2 is a real lousy battery that last 1 year or less. With a risk of leaking and destroying the internals.
And good luck to you when you wash your hands, cos the water will seep inside. The rust created inside will cost you a lot.
OT:
LOL why hoot quartz sia?!
since hoot tag oredi, ish kum gong to hoot quartz movement reh!
Heng I wear Richard Mille. Can be used for everythingIf I want automatic mechanical watch, I have my Rolexes, APs and Pams.
I specifically bought quartz Tag Heuer because I can play golf, tennis, swimming, fighting, sauna, massage, steam room, drinking, etc with it and it never gets spoiled. It somehow looks better than a G Shock while performing all these activities.
You try playing golf with a mechanical watch. Good luck to you. Even with the anti shock mechanism, it will not last long.
how many watches you have rusted on you?
just go bencoolen the watch shop
I like your reply! SteadyAsk Strawberrycream lo
Oh I forgot liao he tio banned!![]()
Really ar....shucks....I always wear watch and golf.You try playing golf with a mechanical watch. Good luck to you. Even with the anti shock mechanism, it will not last long.
