Tech Savys pls help me!!!
eupho8989
Ty for ur time for reading tis post.
I had a dell Vostro laptop faced many problem such as
-unable to update bios due to faulty battery
-cpu speed at at 0.8ghz as my multiplier is stuck at 8
I hav replace the motherboard in china recently and I updated the laptop to windows 10. The motherboard was in my laptop was not from dell but a 3rd part one which the serial number in the bios is gone.
Laptop is a Dell Vostro 3550
specs-i5 2540m
4gb ddr3
amd gpu
240gb ssd
The cpu speed is always stuck at 0.78ghz in task manager....
caterham7
Sounds serious. Maybe consider a cheap laptop, e.g. hp stream 11 $299
If you already have a monitor, mouse, keyboard, can consider asus chromebox cn60 $189
eupho8989
I may wanna send tis to dell or pc dream to repair not sure whether will cost a bomb or not :(
PC_Dreams
Featured Distributor for Notebook Clinic
We can try flashing the BIOS, but it might or might not work since the board is not original Dell. We can't confirm now. :)
We pluck out the BIOS IC and flashing on it directly. Will backup the existing BIOS before flashing.
Cost around $120-$150 before GST (The higher tier is because your board is not original and we are unsure of its status, so it might need more than flashing to work). If can't work, no charges. :)
PM us if you like to come down. We do not offer this as a standard service, so need to let us know first so that we can arrange for you.
Cheers!
