[Tecware Alpha M] Best Fan Configuration
Crayon Shinchan
Hello would like to have advise on the best configuration for my case
Red --> Fan direction
Yellow --> CPU position and exhuasting
Green --> front top fan unsure should be exhaust or intake.
Pink --> GPU and fan facing downwards
Fans: 2x 140mm intake, 3x 120mm exhaust (1 for rear, 1 for top left, 1 for top right)
Most concern is top right fan.unsure should be exhaust or intake?
link to case: https://www.tecware.co/alpham
Thank you
hg2
Using a Alpha M white,
3x120mm front intake. (bottom one to cool the PSU)
1x120mm rear exhaust.
2x120mm radiator exhaust.
Balanced in/out, not fantastic
Crayon Shinchan
Oh thanks.
Just to enquire is your clearance between gpu and case very narrow?
My seems to be quite narrow. Thats why looking to increase intake for air flow to aid cooling.
Sent from
东汉末年至三国时期(刘备→刘禅) using GAGT
SEvsNK
Front - Intake.
Top (hot air rises) and back - Exhaust.
For graphics card - Not much u can do since the clearance is only so much
Crayon Shinchan
Front - Intake.
Understand. Top left definetly exhaust. How about top right?
Sent from
hlots123
try remove pci slot covers at rear, see if it helps gpu temps...
SEvsNK
Sent from
Also exhaust, else u will be recycling the hot air it was exhausted from the other fan on top
ragnarok95
Senior Moderator
Senior Moderator
Front in, back out.
Top left and right, you try with both exhaust and both intake and see which one give you better results.
hg2
ZhugeLiang 諸葛亮;129192500 said:
Oh thanks.
Sent from
40-50mm clearance, add a fan underneath and side of GPU, no difference in temp... guess 3 in/3out is optimal, so removed.
The inlet usually very very dusty after a short while, that's why i keep to 3 max and the front only for easier maintanence..
Lil_d3viLz
Hijack thread. What if my case doesn't have back/front airflow?
Top Btm Side only.
360mm each side.
KarmaKarma
I'm using Lian li 011d xl, layout almost same as you. Tried different setup, best one for me is
side intake x3
Top exhaust x3 (aio rad)
Bottom intake x3
Sent from Asus ROG_PhoneII using GAGT
ItsmeagainhK
I’m using meshify c.
Top 240mm rad Intake, front 280mm rad intake. Only exhaust is the back 120mm. Reason for this config is because when I set top to exhaust, my cpu aio cooling capacity is drop because it recycles the already warm air from the gpu aio which is in front.
KleoZy
Hi TS,
no one can actually suggest what's right for you. you will need to test it out yourself which is what
ragnarok95 mentioned. It takes time and the most important part is patience while doing this.
Below is just for your read, if you find it lengthy ignore them.
PC Airflow is no difference from torquing a vehicle, you might get good parts but if you do not know how to torque it, it's as equal to driving a default settings.
Some factors you might want to consider.
1) Determine what kind of user are you? for leisure, work or gamer.
2) PC cooling and cooling fan used?
as listed on your diagram, you are using non AIO cooler for your processor but what fans are you using? normal or particular? Example noise factor, CFM (air/wind strength) and yes many can just use Noctua. No doubt they are of good build and produces less noise but there are cheaper alternative.
3) What kind of style are you looking for
a) Positive airflow - all intake, which lead to less dust accumulation (just make sure your case does have fan filters)
b) Negative airflow - all outtake, which lead to hell lot of dust accumulation inside your case.
c) Balance airflow - the hardest to achieve but is not impossible
don't be mislead by others, have your own concept and work on it. Yes you might see bros here talking about Noctua most of the time, no doubt they are quiet and give good airflow but there are other alternatives.
4) Making use of UEFI or the software that comes with your motherboard to tune rpm vs temperature.
which most does.
5) There are three zones to consider, 1st section (CPU Zone) , 2nd section (GPU Zone) , last section (PSU Zone) , which you will need to understand and to be able to control the airflow inside your case.
Again you have to try out by yourself.
These are my personal experiences.
I do take in suggestion and quietly take my time to plan and to torque the airflow. I mainly use my pc for work, video edit, 3D and graphic works. I am not a hardcore overclocker as I do not fix a voltage and run it always at high Ghz (some will do it straight 5Ghz) this will damage pc component in the long run and will warp the PCB of your motherboard or GPU or Rams. It does not matter how much you bring down the temperature as pc component are constantly generating that much heat.
I have my reasons to do the below illustration as I need my PC to be functional till the end of time (at least 5 years down the road)
Am using a LanLi Lancool II case (without mesh infront)
I did this to give more air flow at least to the PSU and GPU area
Purposely mount my radiator this way for easy maintenance (dust is a factor on airflow)
Purposely mod this GPU like a box so that only hot air are pushed to the back an not inside the case
I know the strength of my fans and to use this application "SpeedFan" to have total control. you can find the guide here by Jayztwocents
I am happy of what I have archive in temps, performance and cleanliness of the case.
As said, some might say why waste of time. well to me is worth spending time on something I love. I gain to learn more and being practical in whatever I practice with, be it in life or at work.
Solidus_GZ
Here's my fan direction, it reduce my gpu temperature by 5 degrees.
Usually when I play cod I run about 80-82 degrees, now its 75-76ish
Crayon Shinchan
Thanks for all the comments will go through it.
Just a questions that many peoole seems to raise is. Top right fan as exhaust isn't it drawing away alot of the intake air from the front intake near the top?
Sent from
Solidus_GZ
we had to understand that hot air raise, cool air sink, hence as air is hot, it expand and disperse upwards, you need a lot of space and surface for the air to disperse out that why i had top 2 and rear 1 as exhaust fan,
86technie
Sent from
Top fan is to take away heat from mosfet (the area with heatsink beside CPU), ram and let hot air out quicker.
Unlike in the early days, PSU is top mounted so heat can't escape that quickly since only one exhaust fan.
Later PSU was bottom mounted improving air flow.
The case you are using a m-atx, if you feel temps are quite high especially if you are using a high end graphic card.
Suggest change to a mid-atx case with more room for the graphic card.
ItsmeagainhK
Can try removing the exhaust fan located at the top that is nearer to the fan. Cooler air can have direct path to your cpu cooler and positive pressure as well.
