[Temperature] CPU & GPU idle & load running temp - Please share here!!
12122012
is something wrong with my CPU?
its at 50+ deg when i not even running any program.
and i just clean the heatsink a few days ago (using compress air without detaching from the chip).
i see that all your 4 cores running 3190MHz Min. check your Power Options setting. use Balanced instead of High performance.
BombVoyage
i just checked. i am actually running on Balanced setting :s13::s13:
i tried reducing the max CPU performance from 100% to 80%. (Balanced setting default is 100%)
the CPU temp drop to 45 - 50 degC
is your min CPU state 5%?
chevalier88
Using i5-4460
Cpu idle temp..58 highest and min 49.
Using Intel stock HSF..
Is the temperature alright in our weather? or I should reapply thermal paste + get a new HSF?
AnTiLooP
AVerage utilisation eg browsing web : 32-35C (non-aircon)
Gaming temp: 42-46C (non Aircon)
xtractor
Aircon on 25°C
CPU
Idle+Browsing Temp=35°C to 39°C
Gaming Temp=55°C to 69°C
GPU
Idle+Browsing Temp=38°C
Gaming Temp=75°C to 80°C
hlots123
Using i5-4460
i've i5-4440 on stock intel hsf, casing only 1 rear fan
idle in low 30's, aircon est 26-27c
haswell quite "recent", dun think the intel thermal paste can be dried up...?
Krabs.
no point comparing idle temperature as the sensor is only accurate at the last few degree celcius before boiling point of water , which is also the shutdown temperature of the cpu chip to prevent damage
the sensor is there as a safety mechanism .... using it for fan noise control is secondary .... using it to compare idle temperature is inaccurate and not it's designed function
that's why we sometimes see idle temperature 2-3 celcius lower than room ambient temperature on a cool rainy day
hlots123
yes, idle sensor temp is slightly off actual temp
but 50s vs 30s range still tells u something is off...
BlackSmokeInTheSky
just my contribution to this thread -
i7 4770k overclocked to 4.4ghz @1.249 (prime 95 stable) with H100i and noctua nf f12 fans
ambient: 30 C
idle: 40 c
load: 71 c (aida 64 1 hr) or 100 c (whuuttt prime 95) or around 78 c gaming (cos my gpu is mad hot)
i1magic
Using i5-4460
Not sure but should be ok based on stock HSF.
If you want to improve the temperature, will have to get another after market HSF liao.
CrispyPeddler
hi guys. recently install msi afterburner and rivatuner and notice my ingame cpu temperature at 90~100++ constant. i think its been like that quite awhile and cpu still seems fine.
is it normal to have that ingame? currently using stock cpu fan..
Koenig168
That's seems too high for a i7-3770 at stock. Time for a fresh coat of Arctic MX-4.
CrispyPeddler
really? so far the pc seems still running fine..:(:(
i have cryorig c7...do i need to dissemble whole pc motherboard to put in that?
update*
just change cpu fan to cryorig c7..the hardest part is putting new thermal compound. once slap the fan, not sure how to thermal compound move.
but anyway, now the temperature while gaming is around 60~70..
