Tennis match problem
diminishin
Hi this should be a simple one.
Let's say we have a tennis match between two players. The game is set as first to N wins. Write a function to return the winner.
Input:
String array (Players who won that round), random size of up to 10000 - [A,A,B,A,B,...]
N - Integer
Expected: A or B
Please put spoilers in your submission
davidktw
A naive one from me first.
Solution
  • O(M), M is number of games played
  • input from arguments,
  • don't care how many different players are there too.
  • no answer if it is impossible to reach N
UPDATE: STRICTLY A WRONG SOLUTION THAT WASTED COMPUTING RESOURCES. DO NOT FOLLOW THE CODE BELOW.
Perl:
use strict;
use warnings;
# assuming number of games won by any players <= N
my($games, $N) = @ARGV;
my %winner = ();
foreach my $c (split //, $games) {
  if (++$winner{$c} == $N) {
    print $c, "\n";
    last;
This is not a recommended solution, but will be the most hardcore I can come up with using perl. Just for fun though.
It's not meant to be nice, it is meant to just work. (^.^)
Perl:
eval{$ARGV[0]=~/(?:(.)(?{++$w{$1}==$ARGV[1]&&die("$1\n")}))+/};$@&&print"$@"
Output:
Code:
$ ./tennismatch.pl ABBA 0
$ ./tennismatch.pl ABBA 1
A
$ ./tennismatch.pl ABBA 2
B
$ ./tennismatch.pl ABBA 3
diminishin
Solution
Perl:
use strict;
use warnings;
my %winner = ();
    print $c, "\n";
    last;
Perl:
Output:
Code:
A
B
Nice, but can u make it even faster?
davidktw
I feel like this will be a major hint already, but can u think of a o(1) solution?
Sounds like a question that I didn't read properly :)
Code:
// assuming `games` is the input array of characters
games[games.length - 1] // minus the caveat of no games
diminishin
Code:
U got it. I wanna make this an interview qn to test candidates critical thinking, what do u think?
davidktw
Sure why not. I did fail it, didn't I ? :)
@diminishin
However I must indicate. It would seems the inclusion of Nis extremely misleading. Because your Nis constrained by your games array input.
Simply for a game array input of ABBAA, you can't have any values other than N=3. Games inputs like ABBA is invalid too.
Hence on 2nd thought, I probably don't think this is a good question.
diminishin
@diminishin
Yes this is done on purpose, N serves no purpose at all. Hmm, maybe I should find a better way to phase this qn?
