The Power Supply Chart
robert_bondi87
Speccing a midrange PC for a friend.
Enhance ENS-0555 550W @ $135?
Seasonic M12II 500W @ $125?
Thinking of getting a 4850.
Not doing sli/xfire. Dualcore cpu. Single hard disk.
Budget is $100-150.
Need recommendations.
Thank you.
p.s. This is the proper thread to ask for PSU advice right?
BryanWu
April/May 2011 Value/Quality for Money Power Supply Recommendation
Removed. Deemed as infringement content.
nez
Extending molex wires
BryanWu, i have a M12II-500. Intending to use molex extension wires (50cm if i can find)
Would like to know if there is any limit to how long the wires can be extended before it start losing too much volatage across them.
Thanks
arkangel010
Need help on deciding PSU :D
Hi :D i'm currently running the following -
Intel Core 2 Quad (2.83Ghz/1333Mhz FSB/12M Cache)
MSI P45 Neo2-FR Mainboard
Aeneon X-Tune 1GB DDR2-1066 CL5 RAM x4
Seagate 1TB SATA-II HDD
XFX HD5870 1GB (875M) DDR5 XXX Edition
I understand that using a wrong PSU can be disastrous and be at the losing end. But how about too much power say 1000w, can it hurt as well ?
How much power do i need and what kinda brand is reliable ? budget 150 - 250.
appreciate some advice, thank u all :D
Tairren
Power Supply enough?
Hi,
I wanted to build a computer and the parts are:
Giga byte Z68P-DS3
I5-2500
Seagate 1Tb 32M
Seagate DDR3 2Gbx2
XFX HD 6950 800M 2GB DDR5
Cooler master hyper 101 cpuFan, C-MASTER Vortex Plus CPU Cooler, 212 plus(with 2 fan), Cooler Master V6 CPU Cooler.
I don have air-condition in my room and i'm going to put it under a table where my leg will be(or beside me a small table)
With a DvD writer
Speaker (take it's power from the cpu)
Webcam (take it's power from the cpu)
wireless mouse and keyboard
Need extra power for wacom and external harddisk.
So how much wattage the power supply should i get? I calculate that i need 500w so if i get 520w is it save enough?
Vasilli
whats the total build up power with a asus gtx six eighty and xonar sound card and processor i7 3770k
how much real power needed and how much extra to be safe ? can anyone help me ? answer my question ? kindly please thanks in advance
BryanWu
Hi,
Giga byte Z68P-DS3
I5-2500
Seagate 1Tb 32M
Seagate DDR3 2Gbx2
With a DvD writer
i5 2500 = 95w
motherboard = 40w
HD6950 = 200w
rams = 10w
dvd = 10w
hdd = 10w
4x fans = 20w
4x usb devices = 10w
total: 400w
add 20% headroom = 480w.
500w to 550w should be ok.
Go for higher efficiency units if you have the budget as it produces less heat and lowers electrical bills.
BryanWu
an overclocked 3770k to 4+ ghz would probably consume around 100w-120w
the gtx680 TDP is just 195w without OC
add those plus mobo rams etc which usually adds up to another 100w
and its about 420w. add 20% headroom = 500w
500w-550w should suit your system well.
750-850w if you decide to SLI in the future.
go for higher efficiency PSUs with 80PLUS Gold or Platinum to minimise heat and electrical bills.
Vasilli
with this kind of configuration ?
I7-3770K 3.5GHz / LGA1155 / 8MB / <sticking to this for wait>
Asus Sabertooth Z77 LGA1155 Motherboard
16GB G-Skill RipJaws-X 1866 MHz / Corsair / Kingston
Asus DVDRW
Asus GTX 680 2GB Direct Cu II GDDR5
Asus ROG Xonar Phoebus
Corsair SSD 60GB GT
2 x 1TB WD Caviar Black Raid 0
CM Silent Pro M2 850W Modular
CM HAF X RC-942 Full Black
Microsoft Windows 7 Home OEM 64 bit
Corsair SP2500
Logitech G15
Logitech G9x
Sennheiser pc350
Razer Goliathus Fragged Alpha Control Refresh
what u reckon ? what brand is better for a PSU ???
Spartan11012
Asus DVDRW
Corsair SSD 60GB GT
Corsair SP2500
Logitech G15
Logitech G9x
Sennheiser pc350
I personally like PSU from Cooler Master. Apparently Corsair PSUs are pretty good too. Worth checking these 2 brands out.
GenerationX
i5 2500 = 95w
motherboard = 40w
HD6950 = 200w
rams = 10w
dvd = 10w
hdd = 10w
4x fans = 20w
total: 400w
how u know the watts needed for each conponents ar? Fr google? I also wan to learn how to calculate.. :(
lootr5858
i'm thinking of buying a new desktop, and someone reccomended me hexa 500W psu
does fsp hexa 500W has good build quality? and is it stable?
the tentative comp specs:
1. intel i5 3330
2. gb h77m
3. cm n300
4. 8gb ram
5. 128gb corsair force gs
6. palit gtx 650 1gb (may consider gtx650ti if its price drop to S$150)
7. dvd-rw
8. windows 7 (or 8 but till its stable)
i may even consider creative z sound card if the price of the above specs drop below S$900 (i'm hoping so, since 4th gen is coming out and rumours of 700 series gpu)
i know that 500W shld be sufficient
but is it good?
