The Spectacles Thread. - Part 2
koniie
Any guys can share which shop carries burberry frames? Been to kwang shin earlier but they dont carry it.
yeswecan
What's the price of a pair of Oliver Peoples? Pretty tempted to get one~
veryred
saw a lady with a chanel specs. any idea where to get chancel frame? Don't see them around anywhere
fulaien
Is the owndays PC lens any good? Supposed to filter out blue light from gadgets..
Can wear for normal use even when not staring at computers and hp?
iCuteCube
Hi all,
can anyone share the differences between crizal and zeiss? which is better and for wat?
Also, i saw crizal has anti-fatigue that is for com users then they also got crizal prevencia, which filters blue light that comes from LEDs, coms, phones.
so are they the same?
I actually research a lot on this, as i am currently wearing a transition lens with titanium frame.
Thinking of changing to zeiss or crizal.
From what i heard (not confirmed), zeiss is like more expensive.
The functions that most people want, like simi resistance, both also provide.
Crizal have more choices to choose from.
Just my pov, Zeiss is high quality and high pricing. Crizal is high quality and reasonable pricing to me.
I think i am going for Crizal, going to my friend's shop @ Bedok to check it out before deciding. But i might be making at Malaysia KL, as the price is cheaper, and i visit KL quite often.
rECKleSSfElla
Dont waste time with owndays. Their PC frame pricing is misleading. Last time i went and ask and turns out 60 bucks is just for the frame without any prescription lens. With 1.60 lens, add 100 bucks. Upgrade to 1.67/174, add another 100 bucks. Best thing, the blue light cut is also considered additional add-on, meaning another 100 bucks. Anyway, lens with AR/anti-static coating are already by default filtering blue light from PC screens/gadgets. But if need be, you can go to any optical shop and ask for Anti-EMI(Electro Magnetic Interference) coating but most probably they will tell you everything under the world already included in the lens by default.
Henry Ng
This two brand are v expensive. I usually go for AO which is acquired by Zeiss. AO 1.6 or 1.67 transition is good enough. KL cheaper.
MBEvolutionX
recently made 2 specs.
going to change every alternate days depending on my mood and attire.
both using crizal uv lens.
love them so much ! :o
:D
how much does it cost for each?
mikeeeey
Transitions drivewear good?
Need a pair of shades while driving. But lazy to change between sunglasses and normal glasses.
Normal transitions dont work in car but this drivewear suppose to work even when the car windows already blocked off the UV right?
ahboy82
:D
the 2nd oakley looks good. plastic frame? how much?
masquerati
hello hello!
anybody knows what other brands have similar designs as below (looking for those with silicone nose pads):
shortlisted these 2 but hoping to gather more alternatives!
Oliver Peoples MP-2 RX
Matsuda M3006
joshuatan1984
is it necessary that zeiss transition will have the Z engraving at the corner?.
also was quoted for a pair of zeiss transition less than $200 at queensway, for the lowest index lense. is the price even possible for zeiss transition?
what other ways to check for authenticity of zeiss lens?
hope to get your advice
many thanks
bberry
hello hello!
Matsuda M3006
where do u intend to buy yr matsuda from?
Joelleyuan
hello hello!
:s13: :s13:
am wearing a very similar design to this, in matte black colour. the brand is 滕井太郎.
Alpha0
erm
crosslink switch and sweep is different.
sweep you can change the temple/stem
switch (my 2nd pair), only the lens frame can be switched out (to sun lens).
