Thinning Hair problem
iNETeVO
according to TCM... plastic combs are harmful to the hair/scalp... due to the static electricity...
and its better with combs made of wood, Ivory or tortoiseshell...
Watched the morning channel 8 interview with 1 western and 1 tcm practitioner about managing hair problems....
what do u think?
AikiBoy
Here is more advice:
* Use nixon it will thicken your hair and make it grow faster. Also take a vitamin called biotin good for hair, nails and skin.
where u get biotin? really that good? never took vitamin before isi it like eating medicine? swallow with water?
hwarzoner
hi guys
i am bombarded with so many hairloss treatment over here
so can hairloss experts here can decide if my treatment list here is ok
1) hairloss shampoo = Nioxin or other?
2) hairloss spray = regaine hairloss treatment or other?
3) hairloss food = biotin or other?
4) hairloss medicine = i don't intend to take any at the moment.
is this correct ways for hairloss treatment?
unwanted
Use
Revita shampoo
+ Nioxin Conditioner. Yes conditioner, this is the only conditioner that's meant for the scalp and makes your hair smooth. It preserves your scalp and makes your hair thicker
Use Minoxidil apply on the scalp as treatment.
If all these don't work, and if you want,then take propercia or proscar/4
It's hard for hair to regrow, but you can increase the volume and thicken the follicles at least.
misterfreez
Procerin
Seems that there are quite a few posts about Procerin.
Anyone knows where i get it in Singapore? Should be easy to procure since its not prescription meds like Propecia.
neanea
Use
Revita shampoo
Hair will still not grow on the bold patch ?
AikiBoy
Use
Revita shampoo
that conditioner got side effect not?
hwarzoner
currently eating collagen pill for hair, skin and nail not sure good or not.
curretly using nizoral 2% shampoo.
and nothing else
Vitaall
Here's the story. I was about to start my finasteride/propecia/proscar regime when the Fincar which I ordered from inhousepharmacy.com arrived few days ago. However I got scared after reading horror stories from propeciasideeffects.com and propeciahelp.com. Apparently finasteride can cause some serious irreversible side effects. It's bothering me now and I need some advice to whether I should start taking finasteride. Please help.
i think you read wrongly lah, it should be reversible.
