mopiko_boy
- Jul 16, 2006
from jb, mypharmacy selling for RM195 for 1 boxpodskinz said:hi guys so where do u guys get your proscar from?
fyi, im selling rogaine foam at $35 per mth if interested![]()
mopiko_boy said:from jb, mypharmacy selling for RM195 for 1 box
podskinz said:wow thats VERY cheap, beware of fakes though ..
is the brand MERCK ?
just get proscar and cut it up. they are the same thing. the only thing safe, is saving money.Leonard933 said:hi, well i will like to know.
Any one taking proscar and cutting in to 5 pieces?
Well i have been to malaysia "myPamercy" well those stuff said that normally people buy propecia more then proscar.
As for myself i also buy propecia as to play safe. . .
Isopropyl said:mopiko_boy
haha... that some questions with very long answer. i keep it short.
1) i just started using Avodart nearly a month. in singapore, you need a prescription just like Proscar. in malaysia, you can get from any pharmacy. the cheapest i found is RM190 for 30cap.
2) the cost depend on your usage. i am using 3cap per week so it cost less. reasons i use only 3cap per week is due to saving cost and reduce side effect. if you happen to experience side effect, it will take a very long time for it to go away due to Avodart long half life. i read before some patient DHT level never return to normal even after one year.
3) as you have already mention, Avodart is much stronger than Proscar therefore, the chance of getting side is higher. reducing I 5-alpha reductase might give more side effect as a trace amount is found in the brain. some reported depression with Avodart.
another area of concern is taking Avodart increase testosterone in scalp as less is converted to DHT. testosterone is also one of the possible cause of hair loss although not as potent as DHT. these are also the reason for me to take 3cap per week. the list goes on and remember that i mention that the half life of Avodart is long, so it might be something to think about before you start.
4) 0.5mg every 5days work about as well as 5mg of finasteride daily. so it better to start with really low dose before deciding whether to you want to go on with it or up the dosage.
for oral spiro, i just play around with it. i used to take 50mg daily and experience side effect. basically i have very painful nipple and can feel a slightly lump therefore i drop it to low dosage. i don't know does 50mg daily really help with hairloss, but it really does clear up my acne problem. my facial skin became very dry during that time. after stopping, all hell broke loose... acne problem is back...mopiko_boy said:thanks for the patient explanation.![]()
other than the avodart that u take 3 times a wk, i noticed that ur current regimen includes oral spiro, which i dun dare to try yet... haha
so is oral spiro what u take on the remaining 4 days? or u totally don't take any oral pills on the 4 days?
will u recommend mixing avodart and proscar together in a weekly regimen? as in M_W_F avodart then T_T_S_S proscar..
just follow the expire date. should not be any problem.Leonard933 said:Hi, i will like to know will minoxi 5% expired. if open too long unuse?
But expire date is 2008 any one knows?
And malaysia got sell Folligen ?
i do not know the price of propecia. i using rogaine foam. no irratation at allAsymtope said:How much is propercia sold in mypharmacy?
Rogaine came out with foam form. Anybody used it? Did u suffer from any irritation?
where did u buy rogaine? How much is it?Isopropyl said:i do not know the price of propecia. i using rogaine foam. no irratation at all![]()
Asymtope said:where did u buy rogaine? How much is it?
I know Guardian selling 1 can for $90 ++ 2%. It's very exp
