Thinning Hair problem
Sweetykez
I’m also having hair loss issue till I went for scalp treat at one of e saloon.. my hair loss has since improved now but e treatment quite Xiong and every week.. each session uses micro needles.. pain :(
Try using Wowo Hair care series.. probably can help you or anyone who has this issues:) if y’all want, pm me... it’s probably cheaper than you going to salon every week.. it’s very taxing And time consuming to sit there...
popdod
Hello. I used minoxidil for 20 days CAn i stop it ?
Hi I use minoxidil for 20 days then I stop it. I can sensitive red stuff on my scalp
Are you using 5% minoxidil? if yes, drop to 2%.
If you are using 2% and still get sensitive red scalp, try other brands.
If other brands still give you scalpe problems. then you are not suitable using minoxidil.
Since you are just beginning to use it...then is ok to stop.
but
if you are long term user, is better to continue it.
Else you will see shedding.
Minoxdil is just a lotion to delay the hairloss
you can't prevent it. :(
popdod
Can SIC which saloon using microneedles? And how many mm de needles?
the method is called dermarolling hair.
Quite a few places offer such services.
some used it for facial skin, small amount.
Always find a reputable one. avoid those doggy, cheap home-based services.
:o :(
peacemaker^^
Suffering from red sensitive itchy scalp might be due to the fact that your skin is sensitive to alcohol. May I suggest that you try to use a minoxidil product that doesn't contain alcohol, and see how does your scalp react to it before totally giving up on using minoxidil. There are some minoxidil products out there that don't contain alcohol.
oscarorange
Just sharing... Can google about derma rolling for hair loss. I chanced upon this as I was googling about derma rolling for face.
Just my own opinion,no harm trying if other method doesn't work. It's very affordable too and can be done at home. Just ensure the dermaroller is properly sanitised.
Paranoia08
Hi,
Did anyone switch from Propecia to Generic Finasteride? From NSC or otherwise.
Would like to get some feedbacks..
How’s the effectiveness?
Is there any bad experience after switching?
I’m thinking of switching to finasteride from NSC due to the cost differences.
TIA
kurtgoh
Hi,
TIA
its ok, i'm using generic finasteride for a long period of time.
5mg, cut into 4 portion, bought from malaysia pharmacy, think the cost is around RM120.
I'm only taking it when the hair dropped, along with aloe vera and minoxidil after a good hair wash, sort of conditioning the scalp
oohman
My hair is getting thinner. Sometimes, i can see my hair follicles are really thinner.. i just run my hand axs my head at least 10 strands come out.
Will biotin or similar multivitamins help ? Or st8 away buy minoxidil and try it..
bbbbbw
eat propecia
jonasahah
CHEAP DEAL!!
Selling 100ml bottles of Growell Minoxidil 5% at $75 each bottle. 2 for $150.. The standard price is $55 at national skin centre and $69.90 at Watsons for 60ml.
All original and local import from pharmacy. 100% authentic I bought too many and decided not use anymore. Expiry in 2021. Only a few left…
Keen pls PM?
popdod
Not a good solution.
Cost at least 3k to 5k + to maintain 3 years (max).
It can be a shorter period. 1-2yrs.
While hair transplant cost about $8k -$15k depending no of grafts.
And last longer but still prone to hair loss.
Unless you have $$ to burn.
Else.
If wanna do. Go for hair transplant.
If no $$. Shave bald. :(
popdod
Currently. There are a few phar companies are in their 3rd phase of testing.
Results will be out in either 2020 or 2021.
If you can hang on. Just wait for 1-2yrs for new developments. \o/ \o/
kurtgoh
mine also thinning..
currently back on finasteride, aloe vera and minoxidil :D
vbhelper
what 3rd phase testing?
Lafiel
im using rogaine 5% minoxidil apply on scalp
taking biotin with dht blocker supplement
hair still getting worst
what else can i do
The Sinkie
looking to sell my generic finasteride 1mg @20 bucks per 30 pills - 1 strip (brand dr reddy finax)
expiry is nov 19 for 4 strips and aug 20 for 5 strips
i bought too much..
text me at 9 7 2 6 2 6 5 1 for meetup transaction
