Third party battery durability
u0206397
Bought a third party battery to replace my phone battery which died after 1.5 years.
This new third party battery (not sure if is OEM or not), only used for 7 months and now cannot hold its charge full day.
Is this normal?
WhiteAnt
What phone are you using?
Why not get original battery instead as 3rd party ones not reliable.
ZrE0_Cha0s
maybe u need to reclaibrate your phone battery to the new on. and next make sure u have remove certain apps that is heavy in battery consumption.
koreanlover
Yes can download Battery apps to monitor which apps consume more battery power.
eric3743
Is this normal?
Whether it is OEM or not, it depend on your usage and the phone itself.
Most battery can last for more than 2 years.
Just how often you charge the battery at which % level, best not to totally on zero %.
For new battery it is best to conditioned it by charging to 100% for 1st few charges.
harky
OEM also dont last long too.
just get portable charger although abit ma fan.
what88
Check and uninstall any app that heavy in battery consumption, then monitor if this will improve the situation. :)
