socrates
- Jan 1, 2000
Was just thinking if is I should upgrade my system which is 6 years old which is still working quite well and the following
Intel C2D 6750
Asus P5KSE
3072 MB Kingston PC5300 667
Sapphire Radeon HD6670 1GB
320 GB seagate
1TB seagate
LG 20 GSA H55N dvdrw
Acbel 490 W true power
Centurion Master Elite 332
Win 7 OEM home premium edition
Have my own keyboard, monitor, mouse which can be reused.
Points to note:
1.) not much into shooting games so can retain my graphics card.Which components could I retain in my upgraded system ? Can I reuses my casing, psu for a new i5 and motherboard ? Can the new motherboard fit into my CM332 casing?
2.) not sure if my old LG 20 GSA H55N dvdrw which I think has the old IDE connection fit into the current motherboards. Do current motherboards have IDE ports? Sorry if I use wrong terms here.
3.)Would like to add a new SSD onto my system to speed things. Pls recommend.
4.) Does any shop build for you if say I were to buy the CPU +motherboard, RAM, SSD and I pass them my old casing, psu, hard disk to install in? Recommendations please.
5.) pls recommend a suitable CPU +motherboard. Thinking of getting a i5 and a ASuS motherboard since my impression of ASuS is quite good. So many motherboards and even i5 CPUs out there don't know which is of good value. I will not be over clocking but just would like my whole system to work, multitask faster.
6.) ) appreciate all suggestions, prices, where to get items from and any other tips. Of course would like to keep the budget down.
Thanks eveybody.
Intel C2D 6750
Asus P5KSE
320 GB seagate
1TB seagate
Points to note:
Thanks eveybody.
