Touch Screen problem with iphone 5S?
Brandy77
Anyone having touch screen problem with iphone 5S?
I have some issue with top right corner of the screen. The touch sometimes don't get registered. Intermittently.
Initially, I thought it was my finger. But other fingers also have having issues. Then I ask someone else to try, also have issue. Some time, some time not okay.
Easiest way to reproduce is to play candy crush.
When playing candy crush, try to move the top right corner candy down with the one below it.
Swap the top right corner candy with its bottom candy.
Try it multiple times, randomly. Interchange with other moves also.
Does it register the move all the time?
ecneret_eel
I think iPhones have one of the best touch screens around, if it doesn't work I guess it's time to send it in, take no risk on the iphone experience
marvinz911
i think i have this problem ask well on the top edges, its like u have to press a bit lower to hit a button on the top on the screen if not it wont sense. Always have this problem with the top 2 button on instagram
toblerone
Same here. In fact, it's the entire rightmost column of the screen for me. Swipe a few times then register.
sid4iwpa
i didnt know and I thot my iPhone 5s' touch screen was spoiled. i went to apple service centre and i get a replacement set with a different number and it it still having the same problem. ie. the last column of the candy crush game, the stones cannot be moved/swipe.
to overcome this: change to landscape mode.
I also read somewhere performing the following steps might help and lots of other iphone 5s users reported and post the same problem.
1) Go to your phone settings
2) Look for 'Privacy' and turn it off for Candy Crush.
3) Then go back to main page, scroll down and look for Facebook
4) You should be prompted as soon as you press in. The message prompted is 'There's a problem logging in to your Facebook' (or something like that).
5) Once you've log in frm there, press 'On' for Candy Crush
6) Go back to 'Privacy' and make sure it's 'On' for Candy Crush
and VOILA! It's done!
Hope this helps ya!
source==>
https://www.facebook.com/CandyCrushLifeCommunity/posts/527969490560474
