TPG Technical Discussion Thread
lenseview
I also encounter throttling when using mifi.
If i place the sim into a phone and hotspot, I do not notice throttling
I use this to measure the speed
https://speed.measurementlab.net/#/
normally i just use it to share internet for laptop
Then i si bei heng lo. Those who bought the same model of mifi from the link i share also si bei heng lo. Confirm no throttle. :s13:
The funny part is, there are other user with different model of mifi also no problem. :s13:
phayze
What mifi u using?
phayze
It is true they do not throttle when doing speedtest through mifi. If i connect to VPN through mifi and do the speedtest, the speed is throttled.
lenseview
You mentioned the keyword yourself. VPN. Go figure it out.
lorettatay
Anyone using pixel 3xl for TPG? Slot in but unable to use 4g or whatever attached are the error.
Emailed to tpg till now no solution.
Sent from Samsung Galaxy S10+ PRISM WHITE using GAGT
wuming79
Hi, anyone using neffos TP704A with Tpg sim? I set APN and name to TPG but still no data. Tried restarted phone still no data. I put in Huawei mate 10 and its OK.
hellgunner
List of LTE supported by TP704A:
LTE 2100 MHz
LTE 1800 MHz
LTE 850 MHz
LTE 800 MHz
Thus, cannot use TPG.
zercab
im using iphone but cant activate portable hotspot on TPG. how can I activate this ah?
104305
just got the new sim ytetday, worked fine, but today no signal ? cannot even see any signal?
Sent from 小米,大屏 using GAGT
ChaosPaladin
i have a problem making volte call on redmi 6. tried the APN and *#*#86583#*#* code but still not working. tpg sim is in slot 1 while circle is in slot 2. trying now at woodlands
104305
until now, I cant get any signal, what happened? really, so unreliable?
104305
finally, the signal come back. it culd be due to dual sim, remove 1 card then restart, ok working.
heckcare.der
cannot get signal and cant select network on my iphone 6.
works well with my s9+.
anyone facing the same issue?
David Lai
Looks like the tpg card dont work with all phones that support volte.
My phone has been on volte with singtel card. I put in the tpg card today, and tested whole night also cant get voice to work... data is working though. Signal strength at 11F is happy give you, not happy, test how long also wont give you...
renfred89
Volte only works on that few devices supported and listed on tpg forum, this is one thing u had to acknowledge when signing up for the sim card leh.
Getting data connection is another thing, which iOS confirms supporting. I used it on an iPhone or an iPad can get date connection, but wont work for voice/SMS on iPhone as volte is not supported.
mackie8
im using huawei E5372Ts-32
i dont get a signal ...
do we need to use specific settings? coz usually i just put simcard and all ok
