Track lights
wahkao3
anyone know what is the common type of track light rail sell in Singapore ?
i google there are H Style / J Style / L Style
thanks :D
so are track lights standardized?? or there are 3 types, H,J,L and not standard? we are very confused
XGZ1503
I am looking for LED track light bulb replacement. Just wondering for same 5w bulb have choice of 12v and 220v...
Anyone knows what is the difference?
Renobasics
The base is still a track. Another pro is that you can change to any kind of light. Eg: pendant lights, spot light etc. Just terminate it to the track light connector like I did for the kids room as in photo. My whole house all tracks everywhere. I'm the future when I don't like the light structure, I can just change it accordingly and just fix it to the track. It's modular in a way.
Sent from HUAWEI EML-L29 using GAGT
wah these light very cute leh~
saberlancer
Jialat I bought H style lights online and thot can easily buy track in Sg. Turns out its uncommon, anyone knows whr can find? Thx
wahkao3
so track lights are not the same types. There are indeed different styles.
Which is the most common in singapore????
yoongf
Sg tracklights are mostly from taiwan using L system 2 wire.
China NVC brand is H system 3 wire.
I thot can start replacing my old yellowing toyoatar light with taobao ones but seems tracks all not compatible.
This transition to LED not simple. Even fluorecent tube replacement having problems. Led tubes 16W cant produce same light output as current 36W fluorescent tube
saberlancer
Just to update.
My taobao lights arrived. I bring along to shops to test. Now installed..seems fine.
lambdafreak
Just to update.
Hi saberlancer,
I've also bought track lights from taobao and didnt know there was different track types, and am having trouble finding the H-type. Could you share which shops you went to that had these tracks?
kleong
Are you guys using integrated or non integrated track lights?
micromousez
do this require false ceiling?
cscs3
I have LED downlights & cove lights with LED strips.
When downlights spoil it could be the bulb or driver, if driver good luck cos contractor had to cut a whole in the false ceiling to replace it then patch back.
They are also not lasting. Within a year one LED strip blew leaving half my bedroom in the dark. Few months later one downlight in my bedroom blew. Shortly after one living room downlight blew.
My parents flat also similar issues.
True, many people though LED can last for long but actually not. The electronics portion have same life to start with, then we have different level of quality with LED too.
Another issue of LED light is they may not be plug and play type. So when it come to end life, you may need to replace whole light vs just the LED bulb.
Light Makers Singapore
Buy lights online or from lighting shop?
Zero knowledge and idea about the type of lights to get? Need warranty and safety assurances?
Light Makers is Singapore’s most established retailer for over 30 years.
As a lighting and customisation expert, you will find affordable and an extensive range of LED products with a wealth of experience to share.
Our accommodating nature aims to take the stress off you with lights customised to your specific needs and make your renovation hassle-free. Regardless of scale and budget, you will enjoy a wide-range of products for homes / businesses from a knowledgeable team for all your lighting needs.
Visit our showroom at 318 Jalan Besar or check out our website at lightmakers.com.sg to find out more for yourself!
brighteye27
Hi, can anyone share if they managed to buy the h track for their track lighting in Singapore ? Just bought track lights from taobao but the track isn't compatible..
karrotgal
Hi, wanna check if tracklight rail able to spray paint (7cf aerosol spray paint), and is there any pros & cons if i spray on it
Windowlover
Consider track light for living room but worry for dark spot ? Any advises for this installation.. was consider track light in front of TV ceiling as seached... and learn about wide beam... it is truth and how to know this LED is wide beam..
