troubleshooting help
redname
Hi,
recently my pc keeps hanging or show blue screen.
the bluescreen says to check on newly installed hardware or disable bios memory.
I've removed my newly installed hardware (PCI wifi card and new GFX card) but still bluescreen or hang
there's no options in my bios to disable memory cache and i have run checks on my gfx card, CPU and ram but all works fine.
can advise what's wrg?
ZrE0_Cha0s
maybe u can state whats the error code? or find a dump analysis to check for the complete list of issues
redname
I think I solved it, might b a clash of drivers as I spend ytd morning to update whatever drivers in the system and my comp behaved properly again.
What's a dump analysis? Maybe can use next time
