TV Recording Card?
croc1977
This card got write leh...on Singapore DVB-T2
For Singapore residence, some DVB-T/T2 reception with indoor antenna might be impaired by walls and high neighboring buildings/structures/trees. In such environments, an outdoor/roof-top DVB-T antenna is recommended. If you are using roof-top antenna with amplified signal, in theory, you should not encounter any reception problem and you should be able to receive all free-to-air DVB-T/T2 channels available from Media Corp. DVB-T signals are not available via Star hub cable input
Hauppauge Computer Works
croc1977
Ok then no problem. Anyway I read that it also supports DVB-C so u can probably still tune to the free-to-air signals from StarHub antenna box too.
but i regret buying it liao...
cannot record in mp4 only mpeg2...have to reconvert again...
waste time
Kiwi8
Deluxe Member
waste time
If u use BDA-compliant software u can probably record in TS format, which can be easily converted to MP4.
