Unable to power on pc
Taunee
First time encounter this problem. I am unable to switch on my computer. There is light on my keyboard n mouse but nothing happen when i press the power on button. Was still using like 2 hr ago, cant start after shut down. Any solution for this ?
ruster
You say cannot power on right? So I assume the cpu fan also not even spinning when you turn on.
OK now you remove the power plug from power supply, then keep pressing the power on button for around 20 seconds.then plug back the power and try to start the pc.
Taunee
Still cant switch on. I tried taking out the battery to try also but nth worked haha. My keyboard n mouse still able to detect power as the logo got light.
daveteo88
Ish it CMOS battery dead? My one the time always wrong. Everyday I adjust it but next day will be wrong again. Now cannot turn on. Ppl tell me ish CMOS battery died already.
jtjt00
Likely your PSU is dead. Get a spare PSU to test.
Kennedy
whatever pc faults patterns, always test the rams first. software test, reseat them, different slots, another one. make sure they are firmly secured in the slots.
kracie17
it looks like your psu is having issues. by any chance you are using seasonic psu?
ttmaxx
If your laptop won't power on, even when it's plugged in could have a faulty power supply, battery, motherboard, video card or RAM. ... Check the laptop's battery and power connector to make sure the connection hasn't come loose. If it's still not turning on, it could be a problem with an internal component.
Taunee
I bring to shop and it can turn on straight. But when i bring home it did not work again. I try changing 2 cable again but still cant. I even try at other power point but if cant power on the pc. So weird.
Taunee
which shop best to do troubleshooting and repair ? only thing scare is bring to shop than nothing happen again. Will it help if i take video and show the shop ?
us spy
seem like its your monitor spoil, i dont think u bring your monitor to the shop to test right? if you bring to shop and it is working, i believe your computer is working fine, sound like something else is not working. Might be your monitor. See if you can try to navigate your PC to play video without monitor, if got sound then 100% monitor spoil.
