Upgrade to MATX build
darkortal
Wanting to upgrade from my current build to MATX build for space saving.
Graphic card and monitor just changed recently so no need upgrade.
Computer used mainly for watching videos and playing games at mid setting.
Kindly advise!
jedi5diah
enforcer not very big what...the most matx is shorter but fatter/longer...
Koenig168
There are different types of mATX case. I just migrated a system from one mATX case (HP Pavilion Elite m9498d) to another (HP SlimLine) and the difference in size was quite substantial.
MoneyFace =p
You will have tough luck finding mATX Z77 motherboard these days, let alone mITX ones...
jedi5diah
mATX can have anything from humongous 41 litres Arc Mini R2 all the way down to 11 litres Jonsbo C2....
gg with jonsbo compact chio cases...ofcos if you have the cash to burn why not...
I am willing to change a new cpu and mobo if required.
if you have the juice to spare itz pretty easy, start by choosing the case you love to have...
ZrE0_Cha0s
I'm looking for shoebox case so can put on small desk.
Enforcer takes up a huge chunk of space when put on desk.
shoebox case?? u mean like female high heel this small? its like u might as well get those asus or zotac mini pc bro :s13:
darkortal
Yes most of the parts are 6 years old already and in time for a change.
The problem is my case and mobo will need to fit my EVGA GTX 960 which is
Height: 4.376in - 111.15mm
Length: 10.1in - 256.5mm
Width: Dual Slot
