Upgrading graphic card,need advice & help
rAiNyMj
Hi all,
hope any expert can help.
im currently using AMD Radeon R9 200 Series.
and it just keep crashing even when im playing dota 2.
if i just wanna upgrade my graphics card, what options i have?
narkizy
Hi all,
If you're comfortable with just MOBAs then dunnid to splurge on a high-end card while upgrading
A GTX 1050 would be more than good enough. Wanna go ultra cheapo can consider 950.
kracie17
you might want to find out what is causing the crash first before heading to buy a new card.. are the temps too high? are there any artifacts on the screen?
jtjt00
TS, list down all parts of your rig like those on the right -->
rAiNyMj
check the drivers first... :s12:
re-installed . only crashes when gaming . RMA before few yrs back but lazy to fix it cos quit gaming.
but my budget is below 300 hopefully for a decent GPU can play most games.
my specs are as below
MB: ASUS B85M-G43 + i54460
GPU: RADEON R9 270X 2GB DDR5
SSD: crucial mx100 256gb
RAM: GSKILL DDR3 4gb x2
PSU: 550W
rAiNyMj
no artifacts, just crash and recover in 5s.
is there any software i can see whats the problem?
kracie17
you can try running the amd catalyst program and see the temp from there otherwise can use gpuz. does it crash when you are surfing the net? if not, how old is your psu? do you have spare if so you may try
rAiNyMj
my PSU quite new, less than 3 yrs old. that time replaced one cause not enough power.
only when i play dota will crash, other than that all ok. (sometimes only )
rAiNyMj
anyone can recommend GPU below 300 and suitable for my MB and my rig?
really no idea why my GPU keep crashing
deepblue_82
PSU: 550W
i dont mean reinstall driver... change a driver and try if it still crashes, if u wan to change u can look at gtx 1050... under 200
