upgrading to larger boot drive help
samloi
My old boot drive out of space liao. Going to get a 250 or 500gb SSD to replace. Most prob the samung 850 evo series.
but how do i migrate from the old drive? Read that some cloning softwares are needed but then i dont trust those websites 100%. Can bros here give some advise? Thanks in advance
jarred1223
if you are buying Samsung SSD, use Samsung Data Migration Software to clone
eddief4
Use samsung data migration for evo. I migrated from my crucial M4 128GB to evo 250GB with no problems.
Easeus backup is another good cloning tool but the samsung data migration is already pretty good so stick with that if you use evo.
jtjt00
If you want long term stability and reliability, fresh install OS instead of cloning.
katata
Heard people recommend Acronis. But really, the one which is easiest to use is samsung migration which comes with your ssd! Just install the software first and follow instructions
commach
Acronis don't even need to install, create a bootable disc/flashdrive and boot up the system to perform cloning.
Why would anyone want to clone the installed cloning software to a new drive is beyond me.
ondooy
another way of making free space...
if you have a secondary drive, relocate your documents, diwnloads, pics, vids to your secondary drive...
reinstall programs to your secondary drive, make your ssd only for os. have your page file set on your ssd..
reduce recycle bin allocated size, set size only on your secondary drive.
