USB 3.0 Front Panel with Two Ports
iamnickelless
[Question] USB 3.0 Front Panel with Two Ports
Hello, I would like to ask if this piece of hardware will work with a Motherboard that does not have USB 3.0. Thank you in advance! :)
harharhar
Only works with motherboards supporting internal USB3.0, unless you manage to find some sort of adapter.
enenyi
u will probably need to buy those add-on PCIe cards that are meant to provide USB3.0 support. Else u wun find anything to connect this USB3.0 front bay panel to.
orbvius
No it won't work unless you have a converter to usb2.0.
Look at the pins layout
You need additional converter like the one below.
