USB PD power adapters
lemonn
Anyone gt any recommendation on USB PD power adapters and powerbank? for Switch :D
Switch requires 15V PD, so you should get the Aukey PA-Y10 or Y12 adapters.
For powerbank go for the Anker Powercore 13400/20100 which officially supports the switch PD standard.
007Mi6
USB PD at 15V and 2.6A or 39W needed. Ideally, get a Aukey PA-Y10, which I am ordering for my laptop. It has 15V 3A USB PD and a 5V 2.1A USB A for your other devices, great for traveling.
Xiaomi 45/65W laptop chargers also provides 20/15V charging. I have the 65W. I also have a Tronsmart 30W USB PD plus 18W Quickcharge adapter, totaling 48W. all above buy from Qoo10.
Powerbank wise, try Xiaomi 45w 20000mah QB820, which I have. Bigger one will be Aukey XD26 26800mah 45w.
https://www.hardwarezone.com.sg/fea...how-select-power-adapter-or-power-bank-switch
007Mi6
Is there anything special about the Nintendo PD standard? It is still USB PD 2.0?
lemonn
It's a half arsed implementation of PD, iirc it supports 9V or 15V undocked, but for the dock to work, it's strictly 15V 2.6A.
Technically any charger that conforms 100% to the PD2.0 standard to work, but to be on the safe side, you need to look out for the 15V 3A rating :)
Our s730 is what spec ah??
