Using an office pc case to build pc
Alexls
I wanted to use dell optiplex sff case to build pc but cannot because of btx, proprietary psu, drive etc
Is there any sff office pc case that uses standard atx/matx/itx components? I like the aesthetic of sff office pc cases
hellspawn_one
Most of not all prebuilt pc by major retailers (hp, dell...) Uses propriety components.
You can't find those compatible components (brand new) that fit without modding the case
Sent from my phone using GAGT
alamakazim
Your best chance is to 1 by 1 google
Search by image
Dell optiplex sff internal
Whatever sff internal
alamakazim
Even if u find 1... The layout is so customised for the motherboard,psu and casing
U probably need to file some metal parts etc or whatever it takes to fit some stuff inside
singupingu
Inwin Chopin? But cannot put gpu. Maybe those single slot, low profile ones like GT 1030, but I'm not sure whether it fit or not ultimately.
Sent from OnePlus ONEPLUS A3003 using GAGT
Prepare to drill holes lor, i did it for my colleague.
Dell's cases are not bad
