VESA mount adapter for S2340L
evq
Not looking for the stand, looking for the adapter that can enable the monitor to be mounted on the stand lol
The s2340l don't support vesa mounts by default, must find 3rd party adapter
oic. sorry cant help
commach
At such insane price, consider change the monitor to VESA mount model.
sharkapl
For amazon, just use a 3rd party forwarder.
EZBUY or CGW
EZbuy pretty cheap but waiting time longer
looking for this vesa adapter so i can do use the display in a 90degree orientation, any bros bought this type of adapter in SLS before? amazon has it but does not ship to sg (dont want to use forwarder as well)
Sell your 2340L and buy a U2417H bah.
90 Degree Mount are sibei expensive.
devilwahaha
im thinking of getting a stand that can rotate de lo, those kind sexpensive ah?:s22::s22:
So you want it vesa-mounted and still stand-mounted sitting on the desk?
http://www.amazon.com/VESA-Mount-Adapter-Bracket-Monitors/dp/B00UUMA7SS
http://www.ebay.com/itm/VESA-Mount-...40L-S2340L-S2340M-S2240L-S2240M-/161483801627
Qoo link is overpriced POS btw. Plenty better stands at cheaper price elsewhere.
Whats your budget anyway? Makes more sense to just get u2414 at this point or a used u2312.
Kusanagi
don't have anything currently, I have a VESA mount for my s2340l, but definitely can't rotate it because it is slotted in
yau_chee
Maybe u can try something like this below:
