Did you do anything to get this enabled?![]()
Android Auto now works in Vivo XFold3 Pro on China ROM![]()
In settings, search android auto, the Andtoid auto app also should be downloaded iirc.Did you do anything to get this enabled?
My experience with china rom, android wear and android auto not working..
For me I kena b4 also but i just try different networks until it works lol...If I edit pictures there is a AI and cut out function. But always show network error. Anyone has same issue? Jovi scan some function also show network error.
As in I'll try my home Broadband wifi, office wifi, own hp line data. Just keep changing different source of dataCare to share what you mean different network. I am on starhub.
Doesn't work for me, error still thereAs in I'll try my home Broadband wifi, office wifi, own hp line data. Just keep changing different source of data![]()
You uninstall that? Does it affect other app?No such problem with bon Jovi since I leave it uninstalled
Never installed itYou uninstall that? Does it affect other app?
What's that?erase exam papers handwriting.
Not for me. Both fingerprint sensor works well for me.
Both of you had your thumbprints registered on the big or small screen?working for me as well
The ultrasonic FGPS on the big screen cmi , can't detect my thumbprint most of the time, am I the only one?
I even peeled the default film off hoping to have a sensitive response of the FGPS but I was so wrong
The screen is now left with unsightly markings of the default film
Just the small screen.Both of you had your thumbprints registered on the big or small screen?
I had these experience too ...If I edit pictures there is a AI and cut out function. But always show network error. Anyone has same issue? Jovi scan some function also show network error.
i did it on the small oneBoth of you had your thumbprints registered on the big or small screen?
