Wall mount / bracket question
alanchia67
This thread helps you learn how to mount the TV and discuss where to get the brackets and what comes with your TV.
What is a good height?
A rule of thumb is that the centre of the screen should be slightly lower than your line of sight.
Eg for a Pioneer plasma that works out to be about 90 cm above the floor.
Not every company lets you have the stand as well as the bracket, so it is best to ask.
Make sure your wall/wall feature is strong and connect all the cables first as it may be hard to reach. There must be enough clearance for connections and heat transmission.
http://www.soundandvisionmag.com/tutorial/1406/step-by-step-how-to-mount-a-flat-panel-tv.html
Step By Step: How to Mount a Flat-Panel TV
by John Sciacca
May 2006
Is getting a flat-panel set out of the box and onto the wall something you can do yourself, or do you need to hire a pro? Assuming you don't want to run any wires inside the wall, mounting a flat-panel is probably a "6" on the difficulty scale. So if you think you're up to the challenge, read on!
STEP 1: CHOOSE THE RIGHT MOUNT
There are essentially three types of wall mounts: flat, tilting, and articulating. Flat mounts are the most popular and least expensive. They hug the set tightest to the wall, creating a sleek, modern, my-TV-is-really-a-work-of-art look. Tilting mounts let you angle the TV downward, usually from 15° to 20°, but they hold the screen several inches farther from the wall. They're great if you have to place your set higher than a comfortable viewing position, such as over a fireplace. Articulating mounts offer the most versatility. Not only can they be pulled away from the wall and tilted up and down, but they can be rotated up to 180° for viewing from just about any position.
STEP 2: GATHER YOUR TOOLS
You'll need a tape measure, a level, a pencil, a finish nail and hammer, a socket-wrench set, a screw gun with a Phillips head, and a stud finder. If your TV is bigger than 32 inches, grab a buddy to help out. Large panels are heavy, and dropping one would really suck.
STEP 3: GATHER THE PARTS
You'll want a rock-steady way to secure your TV to the wall. With wood studs, that means using lag bolts. Most installers recommend 5/16- inch lags, which some mounts include and some don't. If you're mounting on concrete or brick, you'll want the appropriate anchors. If your walls are framed with metal studs, you'll need toggle bolts. (Using toggles in metal studs is tricky, so unless you have some experience, consider having a pro do the job.)
STEP 4: ATTACH THE MOUNT TO THE PANEL
Most flat-panel mounts have two main pieces: the part that's fixed to the wall and the part you attach to the TV. This second part is usually called something like the bracket interface or the mounting plate. Find and mark the vertical centerline of the TV and attach the bracket to the panel. This is easier to do if you lay the panel face-down — just make sure it's on a flat surface on something soft. Some mounts also have a part called a hook bracket that attaches to the interface bracket to marry the TV to the wall mount.
STEP 5: FIND THE STUDS
The cardinal rule when hanging something is: Make sure it stays put! So if you're installing anything heavier than a 20-inch LCD, anchor the mount in something solid — which usually means screwing into studs. [Fig. A] Using a finder is the easiest way to locate studs, but electrical outlets are also reliable since they're usually mounted to a stud. Also, studs are generally placed 16 inches on center, so once you've located one, you'll usually find the next one that far away. Tapping the finish nail into the wall is a great way to make sure you've found a stud. [Fig. B] Determine how high you want the TV — placing the vertical center of the screen at about 5 feet is a good start — and then use a pencil to mark on the wall the location of the studs and the desired screen center.
STEP 6: ATTACH THE WALL PLATE
Center the wall plate at the location you marked for the screen center. (Most plates have a small hole or slot so you can see your mark on the wall.) Use a nail to lightly hold the plate on the wall while you level it. Once it's level, drill some pilot holes for your lag bolts (15/64-inch holes for 5/16-inch lags), then screw them in. Doublecheck to make sure you're still level. Before installing the TV, pull firmly on the plate to ensure it's totally secure.
STEP 7: ATTACH THE TV
You're almost done! Lift the TV and attach the top hooks to the mounting plate on the wall — the bottom hooks should latch into place. And that's it! Connect your cables, open a cold beverage, and marvel at your handiwork.
Mod Edit - 18052009
Additional info:
How to Mount a Plasma TV on a Wall[Edit]
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's only 4 inches deep is the ability to mount it right on the wall!
Steps
1. Purchase a wall mount from a reputable plasma TV dealer, and ensure that it fits your TV.
2. Locate the wall studs in the wall you wish to hang the TV on. It is critical that the screws holding the TV to the wall are screwed into the solid wood of a stud, not just into the wallboard. The best way to find a stud is with a stud finder, which is available at any hardware store for less than $20.
3. When you find a stud, mark it in pencil on the wall. Measure the vertical distance between the screw holes on the mount. After deciding how high to mount the TV, mark in pencil where you will place each screw.
4. Double check that it will be level by measuring the distance from the floor up to each screw hole you have marked. It is crucial that you mount it level. It will be hard to fix after the fact if you do it poorly, so please measure twice.
5. Use big screws. Try #14 x 1.5 inch screws. For #14 screws, drill a pilot hole 13/64" wide first.
6. Attach the mount with the screws. Double check to ensure that it is level.
7. Drill or cut a hole behind the TV to run the wires into the wall, as wall mounted TVs look best if the wiring is completely hidden. Make another hole where you want them to come out. Once your holes are made, fish the cables through the wall.
8. Hang the TV on the mount. Usually, this involves attaching rubber/plastic mounts to the back of the TV, placing them through holes in the mount, and letting it settle into place.
9. Double check the stability of the TV, and ensure that it is firmly in place.
10. Connect your wiring and enjoy your TV.
Tips
1. Don't mount it too high. It's tempting to mount it at picture height, but most people would find it more relaxing to watch if the center was around 40-45 inches off the floor.
2. In new houses, studs are generally placed 16 inches apart. So if you find one, you can look for one that far away.
3. Often, power outlets are placed adjacent to a stud, so look for a stud there.
4. If you're running cables in the wall, buy quality cables that will prevent interference from power wires and other wiring in the walls. Once you get this mounted, you don't want to find out that you have a problem.
5. "Future Proof" your installation by including a DVI/HDMI cable (or at least component cables) through the wall, even if you are not using them today. If you just run S-Video or Composite cables, there is a big chance you'll want to upgrade later. For the cost of an extra $20 cable, just put it in the wall while you have it open.
Warnings
1. After hanging the mount (before you place the TV on it), find a way to add some weight to the mount to make sure it is absolutely firmly in place. Most flatscreen TVs weight around 50-150 lbs.
2. The biggest concern mounting on the wall is wiring in the wall. It's hard to be sure, but be careful
Useful:
http://www.soundandvision.com/content/4-things-keep-mind-when-wall-mounting-tv#JPux2kxcSO1OY3IR.97
4 Things to Keep in Mind When Wall Mounting a TV
As a custom installer, meeting with clients building new homes, remodeling, or just looking to upgrade their entertainment systems is a big part of my job. And after 17 years of walking through job sites and looking at blueprints, I pretty quickly hone in on the few key areas that determine the project’s difficulty and cost.
While decisions like speakers, electronics, and TVs are important, it’s the “big picture” infrastructure items that need to be focused on early. Ultimately, with the correct infrastructure in place, virtually any gear can be installed and—hopefully—leave the project prepared for upgrades and technology changes down the road.
When it comes to installing a new TV, there are four big-picture items beyond just making sure the mount is securely affixed to the studs. These are power, sources, audio, and control. Let’s look at each.
1. Power
Obviously, the TV won’t work without power, and if you can’t just point to the wall and say, “Have the electrician put an outlet right here,” it needs to be addressed. By the National Electrical Code (NEC), you can’t just run an electrical or extension cord through the wall, but there are several solutions like Power-Bridge that allow easy—and safe—power connections without bringing in an electrician. Of course, if no outlet is nearby or you are working with something solid like a brick fireplace, concealing the wire for a finished look will be trickier.
2. Sources
Knowing what sources will connect to the TV determines the type and number of cables that need to be run. Even with just basic cable TV, is there a jack already there? Or can one be intercepted in an attic, crawlspace, or other room? While some source components like Apple TV, DISH Joey, and DirecTV Genie Mini are slim enough to install on the wall behind a flat-panel TV—greatly simplifying Installation—most components require some kind of cabinetry or shelf. The location of the sources determines the cabling length and the installation’s difficulty. We recommend pulling a bundle of HDMI, CAT-rated data and RG6 coax cabling for flexibility, especially if you won’t be using an AV receiver as a source switcher. We have started pulling multiple extra CAT cables to displays, as the wire is cheap and offers so many great uses, from Ethernet, to IR, to HDMI distribution via HDBaseT. Of course, installing some conduit or a pull-line can ease adding more wiring down the road.
3. Audio
With very few exceptions, modern TVs deliver abysmal audio quality; fortunately, there are many ways to improve it. From an installation standpoint, adding a soundbar is often just a single digital audio cable from TV to bar. However, depending where the bar is mounted, this might mean concealing another cable—and power—inside the wall. With a traditional surround system, enjoying improved sound from any streamed programming like Netflix or Amazon Prime requires sending the TV’s audio to the AVR. Again, this can be accomplished via a digital audio cable. However, TVs and receivers have been supporting an HDMI function called ARC—Audio Return Channel—for several years, enabling the TV to send audio back to the receiver down the same HDMI cable it uses to receive video.
4. Control
As the install grows from TV only, to TV with a set-top box, to multiple sources, to adding an audio system, the remote pile grows quickly. Beyond just the convenience of a universal controller (probably the best investment you’ll make in your system), sources located out of sight will require a control solution that can work through cabinet doors or even walls. While infrared (IR) repeating systems are less expensive and can do the job, they are more prone to interference and aren’t as reliable as radio frequency (RF) solutions that don’t require pointing the remote at a target.
Read more at http://www.soundandvision.com/content/4-things-keep-mind-when-wall-mounting-tv#m9q5hAQHvbR2bJGu.99
terrence
LCD TV Wall Mount
Hi guys, need a bit of help.
Where can I get an articulating or swiveling wall mount for 32" LCD TV. (200mm x 200mm mounting holes)?
Thanks for your replies!
kurch
the brand is sanus (www.sanus.com) and you can find this product at gain city (one of the shop) but i think you need to do a pre-order. alternatively, you can buy it online from US but you need to install it yourself. Another brand is peerless (www.peerlessmounts.com).
Geekiest
You can get it from www.nokland.sg , they include wall mount service as well.
Bought my plasma from them and they did the mounting as well.
batigola
Hi all,
I own a Bravia 32in S series. I intend to wall mount it in my room. Can I purchase any generic wall mount & DIY it?
I'm not really a DIY person, but i do own a drill and have fixed some shelfs from IKEA before. Is it better to get a contractor to do it?
Can I also know price wise how much it cost for both wall mount + install by contractor.
Thks alot for your help
PFG
I've got a question about wall mounts though...
Wouldn't the connections behind the TV be obstructed once it's installed on the wall?
Connections have to be made before the TV's up on the wall?
raysusan
do u wall mount your LCD?
if u did so...
then how u guys run the cables?
a picture of yours will be very nice:)
yixiang1
got the same question.. just realised u cant have the cables dangling out from the botton of the panel.. really ugly!
thinking must do feature wall kind of thing...
Kristy_Tan
i am glad i did not wall mount. so ma fun when you want to insert new cables. but i dont discourage you all from wall mounting,
hobbes187
Advantage and disadvantages of mounting
Hi all,
I got my Samsung 40A550 at comex for $1559 + $300 voucher. If you wondering why its so cheap, its a display set.
They delivered already and its really in brand new conditions with 42hrs panel on time. No scratches nor damage. Nowadays they start selling the display sets on the first 2 days... Wonder why...
I am wondering what is the default wall mount bracket that samsung gives? Is it those that can be adjusted or really fixed one?
Anyway, what are the advantages of mounting? I cant make up my mind whether to mount this TV in the living room feature wall cos I'm afraid that in the future if I change TV it might be troublesome...
mikezuper
the advantage is that, you save space since its floating and situated very close to the wall.
disadvantage would be: you cant move it freely. Once decide to change more troublesome also. And addition of new cables would be more difficult to manage.
kayel
Plugging/unplugging cables would be a nightmare cos it's so hard to reach the back without dismounting the tv... And should your TV require servicing, imagine the hassle..
hobbes187
Thanks for the comment. Is it really that difficult to connect the cables after mounting the TV? I have never personally seen how it looks like after mounting but I would think that the manufacturer should not have made it too difficult to plug in new cables rite?
By the way anyone knows if Samsung gives the auto wall mount or just the normal mount for a Series 5? I read in the catalogue that the S5 is with the auto mount but forgot to ask the salesman.
kennyboy
unless you really really confirm you will NEVER shift it then u wall mount.
The only advantage is space saving and look slightly better. If you very hiao then do that.
Otherwise most of us would recommend not mounting.
congster2
usually its just normal mount. auto mount's cost is in the hundreds i believe. it is not very useful unless you really need to tilt your TV often. as for wall mount versus stand, im using wall mount (on my feature walll) and it looks a whole lot better. of course it will be more troublesome when you want to connect cables but it is still doable. moreover, how often do you connect cables? it is a small sacrifice to pay for the TV to look flawless on the wall. :) i also use a switch for one of my hdmi ports (i use those the most) hence i seldom need to reach to the back. even then, if you don't have switcher, there is always the side port which is easily reachable. having said all these, if you don't have a feature wall and by wall mounting you leave ugly cables hanging from your TV, perhaps then you may wish to stick to the stand.
