Wall mount / bracket question
woowhm
Wall Mounting
Hi, any idea if a wall brackets used to mount plasma TVs are universal? ie one can be used to mount a plasma TV no matter what make it is. Thanks.
petetherock
Moderator
Moderator
That depends on whether your bracket is model specific and its specified weight bearing tolerance.
MOD EDIT: merged
The search button is your friend
alvismah
Guys if the wall mount contractor wall mount ur tv abit slanted what will u guys do ???
planetelement
Hi, you can look in my website: www.planetelement.webs.com for more Qns you can also email to me.
is it the norm that the vendor keep the wall mounting thingy .. if i opt to just use the stand ??
are they supposed to give it to me ?
planetelement
Hi, you can look at my website : www.planetelement.webs.com any further Qns can contact or email to me.
zilturo
hi guys,
just a quick question, i wall mounted my 37 inch samsung LCD TV last year, going to upgrade to a 46 inch LCD, can i use back the own bracket that is installed into the wall or i need to install a new bracket?
the current bracket was install by Havey Norman when i bought the 37inch LCD.
Thanks
Milich
TV wall mounting help!
bought my 37 inch LG 55 during IT show. did not request for wall mount. but now i moving house and due to smaller room cant help it but to wall mount my tv to save space. how much is the wall mount bracket? and is there any service available out there that can help me wall mount the tv?
sanji37
i do haf the bracket..i can sell it to u..
bought from harvey norman..pink box..
Milich
Call your retailer to help you arrange a date for the mounting!!!
so.. since i bought from audio house den i hav to arrange with them? will they need any proof of purchase or anything? how much are they charging? can i buy and ask them to bring the wall bracket at e same time? sorry for noob qns just making sure..
SkimMilk
brother, call audio house. I believe LG provides the mounting free. I got the same tv from harvey norman. they allowed me to defer installation. all they did was called lg pple to come over and mount for me.
unclepig
I mean the tv is wall mounted. And it's abit left side lower right side higher. (slanted) wad will u all do ??
normally most of the mount comes with allowance for fine tuning....... just to cater what you meant slanted...
valentinomama
hi, mounted my Sharp 37" last weekend in my small room. I live in HDB new flat, so room is really f******ing small.
Pls keep the stand. I did.
Yes, there is universal bracket for sharp. up to 50"
Standard level above ground is 120cm, which may be too high. so change accordingly, 80-120cm.
Now i got problem trying to hide the messy cables look. Haiz...
Small room problems.....
unclepig
True!!.... with limited space.. cannot built false wall to high the cables....
Bro you can try using those semi circle trunking...for cable management
