wat happens if u forgot tap ezlink then alight from bus
fireflame
Thank you for contributing to the profit they always announce at end of financial year
jywy2005
If you use SimplyGo, can send a claim report. Then they will refund to your cc
Ezlink not sure if can check with their counter service.
Scp173
U be charge from the stop u get up all the way to the interchange the bus is heading to...
Ctrl_Alt_Del
You are charged max fare to the last stop when tapped card upon boarding the bus, then refunded the unused fare amount when tapped card at alighting.
Goodtodo
EZ-Link not so easy. Upgrade your card to simplygo then can simply go!🤣
coyote
someone advise?
Charged maximum trip fare after the system did not get your tap out after xx amount of time. It is because of this xx buffer time given to passengers that, the system is not giving you an instant fare result, because transfer takes time. And the system will not know whether you are still in a transfer or you forgot to tap out, until probably an hour or more later.
Joseph12
Charged maximum trip fare after the system did not get your tap out after xx amount of time. It is because of this xx buffer time given to passengers that, the simplygo system is not giving you an instant fare result, because transfer takes time. And the system will not know whether you are still in a transfer or you forgot to tap out, probably an hour or more later.
Is that why?
Haha
If you take a bus not MRT you go to MRT station and bus terminal & use their machine it'll reflect the trip and amount paid immediately
